CEL issue...tried searching and found nothing
ok im new to 4th gen preludes and the one i have is currently throwing a CEL, but only when the car is started. I tried hooking up a snap on scan tool but it says there are no codes...i know in civics and integras i could just stick a piece of wire in the connector on the passenger side and read the flashing light...can i do the same with the prelude? pics of the connector
ok thanks alot...1 more question......according to that link there are supposed to be 2 connectors, a 2 pin and a 3 pin...am I right?
You are only looking for the blue connector. Don't jump any other one. You are in the right area, you just have the wrong connector in that pic.
thanks alot....i found the blue connector right after i posted my second question
im getting code 41 so i jacked up the car and saw that the O2 sensor had been replaced with what looks to be a "universal" one because the wires with cut and spliced
quiambao1180
Dec 4, 2012 07:32 PM
