no fuel!
Old Aug 27, 2008 | 01:04 PM
blackrocky's Avatar
Default no fuel!
I finally drop my b16a in, converted injectors to mpfi and no start. It rotates but don't start. I check the wiring and that's done correctly. I sprayed starter fluid in the throttle and it starts so that means the distributor is good. I jumped the fuel pump and it works because the fuel sits in the rail but don't spray. Why is the injectors not spraying?
Old Aug 27, 2008 | 01:34 PM
vtecb18c's Avatar
Default Re: no fuel! (blackrocky)
they could be glogged...or the worst its an ecu issue....if you have a buddy around with a pr3 or p28 throw it in and see if it fires
Old Aug 27, 2008 | 03:34 PM
efjones9's Avatar
Default Re: no fuel! (vtecb18c)
did u use the injector resistor box wen u converted it to mpfi??
Old Aug 27, 2008 | 04:29 PM
blackrocky's Avatar
Default Re: no fuel! (efjones9)
I tried my pw0 and d15 ecu and still nothing. When I converted to mpfi I did use the resistor from the b16 harness
dayl
21
Apr 13, 2010 08:06 PM
drsessum
Jun 14, 2009 11:26 PM
90dxb20
20
Apr 1, 2009 08:33 PM
charliebcdaccord
Dec 5, 2008 05:39 AM
SiBuddy00
Jul 13, 2005 08:15 PM
