DC4 Auto to Manual swap
Does civic 92-95 shifter rod work with mod? Does my automatic half shaft and shaft work? I tried to search on web but the answer is never the same. My 3 pedals,clutch pump,all steel line,shifter boot are installed. tanks
Are you referring to the shift linkage from a 92-95 civic. It should work as long it is from a b series motor. And for the half shaft it must be a manual half shaft. There are more articles on team-integra.net on auto to manual swaps. In the process of doing mine as well.GL
