What hardware is needed for OEM ITR lip installation?
i guess bolts on the end of the lip, double tape in the inner of where the air dam is, and the lip should stay on pretty still.... that's how i did mine
If it's truly OEM, then you'll need several u-clip nuts (M6x1.00) and dowel bolts (M6x1.00). Then there are a couple of brackets, screwhead bolts, 5mm washer-screws, and the screw clips.
You can see it on any front bumper parts diagram.
