NEED HELP! idle problem when i turn on a/c
Old Aug 27, 2008 | 08:30 AM
asianeric's Avatar
Default NEED HELP! idle problem when i turn on a/c
hey guys, first off...i searched and couldn't find any results that fit what i was asking....so here it goes...
95 gsr, bought the car without a/c (previous owner removed it). within a week, i sourced someone selling their full a/c system. i bought it and the guy even installed it for me. doesn't seem to have any leaks and looks installed correctly (nothing out of the ordinary). car idles normal around 800rpm but when i turn on my a/c the idle drops to 100-200rpm, sometimes stalls...so when im driving and im in gear, if i put it in neutral the car will stall because the rpms drop.
not sure what the problem is, any ideas guys? any help is appreciated
Old Aug 27, 2008 | 01:47 PM
AnDThEnWuT's Avatar
Default Re: NEED HELP! idle problem when i turn on a/c (asianeric)
maybe the tension on the ac belt is too tight? just a thought. cause the ac compressor is free spinning when the ac compressor clutch isn't engaged.
Old Aug 27, 2008 | 01:50 PM
asianeric's Avatar
Default Re: NEED HELP! idle problem when i turn on a/c (AnDThEnWuT)
ooo, good point...how can I adjust that?
Old Aug 27, 2008 | 01:54 PM
AnDThEnWuT's Avatar
there is a tensioner somewhere in between the power steering pump and ac compressor pump, its a little wheel that you can adjust. This is from memory so i'm not quite sure.
Old Aug 27, 2008 | 01:55 PM
asianeric's Avatar
thanks! if anyone could gimme more details about adjusting it...and pix would help a lot too that'd be great!
also if anyone has any other ideas...but ill try this first
Old Aug 27, 2008 | 02:01 PM
AnDThEnWuT's Avatar
ahh yes i was correct, i just looked at my service manual and it is that wheel, the tensioner bolt is behind the ac compressor wheel you can just adjust from there. The bolt head should be facing directly towards you. good luck.
TUR3Ovtec
Oct 20, 2013 08:26 AM
johnehonda
10
Jul 4, 2012 08:13 AM
Katastrophic
15
Jun 29, 2011 10:33 PM
jster28
Aug 22, 2007 08:16 PM
adan CRX
Dec 1, 2003 03:12 AM
