2008 Accord Shimmy poll...
I wanted to ask those of you that have a 2008 accord, if your car has a Shimmy issue. Certainly the OEM tires are really pretty bad, but it's also been known that the OEM tire pressure settings are way off.
A simple tire pressure adjustment can alleviate most of the typical shimmy issues if applied correctly, that being a front end pressured bias/stagger (eg 34f and 30r).
excluding an issue where the car's toe is out of spec, post up your vote and a response to how your car responds to the stagger/pressure adjustments suggested above
thanks
Schu
thanks
Schu
I see vibrations all the time from the '08 Accords (and most other models). But we have 115 degree summers out here, so maybe it's for a different reason.
Customers complain about vibrations more often on fresh rubberized asphalt, too.
popsep3
Aug 14, 2019 10:24 AM
samster911
Jul 11, 2015 02:49 PM
