NEED HELP on swap advices...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmoobthojboi07 »</TD></TR><TR><TD CLASS="quote">would a jdm b16 motor run good with a gsr(p72) ecu</TD></TR></TABLE>
No. either get the right ECU, get a P28 and get it chipped and run B16 base maps, or get your car tuned on a dyno.
x2, The whole deal with mixing ecu's with other motors is insane cause there is no way the a\f will be right if it was designed for another motor. just get you s300 so you can constantly change it. cause the other thing that peolple dont take into consideration is that any bolt on part like inatke, manifold, fuel rail. all this stuff was takin into account at the time off the fuel map program and when you change it you no longer are getting the right a\f so good luck.
joelmatt89
Feb 4, 2009 06:27 PM
racingant
13
Jun 29, 2005 02:27 PM
racingant
Jun 28, 2005 08:46 PM
