b17 with CTR pistons Compression ratio?
Old Aug 27, 2008 | 01:59 AM
civic2slo's Avatar
Default b17 with CTR pistons Compression ratio?
The specs of the engine is a b17 with CTR pistons with a b16a/b17a head with ITR cams/ITR intake manfold and T/B. OEM JDM CTR/ITR exhaust manifold. I was thinking of switching to blox b's or skunk stg 2's cams because of the comp ratio.
I have search HT and came up with 2-3 different compression ratios. The first one was 12.19 to 1 and the other was 12.49 to 1. Which is right? Hopefully with 91 octane will not ping when tuned. Any suggestions or comments would be appreciated.
Old Aug 27, 2008 | 03:02 AM
alterdcreations's Avatar
Default Re: b17 with CTR pistons Compression ratio? (civic2slo)
how high do you plan on spinning this setup?
Old Aug 27, 2008 | 03:35 AM
civic2slo's Avatar
Default Re: b17 with CTR pistons Compression ratio? (alterdcreations)
8,400-8,600 rpms. Currently the rods and rod bolts are stock. Planning on arp rod bolts but will have to take it apart.
Old Aug 27, 2008 | 04:10 AM
IT GUY's Avatar
http://zealautowerks.com/
This calculator says compression ratio will be 12.47:1 with an oem headgasket.
Old Aug 29, 2008 | 03:56 AM
civic2slo's Avatar
Default Re: b17 with CTR pistons Compression ratio? (IT GUY)
Hopefully 12.47 to 1 is good with 91 octane gas with a good tune.
401tuner
Jul 2, 2007 08:07 AM
LvN
Mar 17, 2006 09:38 AM
PinkMaggit
Dec 17, 2005 10:09 PM
96integraLS
Dec 1, 2004 07:35 PM
akhom
Oct 13, 2002 10:21 PM
