OBD2 Cars - Without FITV or Fast Idle Thermo Valve - How does it function
Old Aug 26, 2008 | 10:15 PM
schumi's Avatar
Default OBD2 Cars - Without FITV or Fast Idle Thermo Valve - How does it happen in OBD2 cars
My understanding is OBD2 cars doesn't have FITV?
In OBD1 cars, Fast Idle Thermo Valve was supposed to raise your idle rpm's when the engine is cold, that's its purpose, and then when the engine warms up, the valve closes and has no impact on idle. The IACV - Idle Air Control Valve controls the idle speed at operating temp.
My question is, how is this acheived in OBD2 cars without FITV?
Modified by schumi at 2:56 AM 8/28/2008
Old Aug 27, 2008 | 05:55 PM
schumi's Avatar
Default Re: OBD2 Cars - Without FITV or Fast Idle Thermo Valve - How does it function (schumi)
Anyone?
Old Aug 28, 2008 | 09:50 PM
schumi's Avatar
Is it already discussed? pl direct me to that...
Old Oct 8, 2008 | 05:06 PM
mitchell_2kSiR's Avatar
Default Re: OBD2 Cars - Without FITV or Fast Idle Thermo Valve - How does it happen in OBD2 cars (schumi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schumi &raquo;</TD></TR><TR><TD CLASS="quote">My understanding is OBD2 cars doesn't have FITV?
Modified by schumi at 2:56 AM 8/28/2008</TD></TR></TABLE>
have you looked under your throttle body and fitv threads to visually look to see if you have one. . its not hard to see. . if you dont have one then no worries. . obd2 is all in the computer, just reads coolant temperature and automatically adjusts your rpm from my understanding
Old Oct 8, 2008 | 06:25 PM
vietnamezerice's Avatar
Default Re: OBD2 Cars - Without FITV or Fast Idle Thermo Valve - How does it happen in OBD2 cars (mitchell_2
In OBD2 tegs the IACV does the job of the FITV... however, automatic integra's have a FITV... if you have a Helms, look it up. I had an idle problem with my car and that's what I learned too
Old Jun 14, 2010 | 12:53 PM
crx026r's Avatar
I have a 94 Integra RS coupe with a swap.. type R block with gsr head.. looks like a skunk2 I/M and not sure what kind of throttle body but I'm guessing it's something obd2 because it doesn't have the FITV on it.
I'm assuming this is why my car doesn't idle by itself when it's cold.
Do I need to buy an OBD1 throttle body? or get an OBD2 ecu?
troyport
Classic Hondas
May 28, 2009 09:06 AM
rorik
Jun 4, 2008 10:19 AM
Markb16a
Dec 5, 2007 05:42 PM
Junkyard2000
Oct 26, 2005 03:16 PM
ATS*Mark
16
Feb 22, 2004 01:00 PM
