DPFI-MPFI Plugs
Need help on this, and yes i have searched...all the MPFI swap instructions i've read don't clarify it much... Will i need to swap the whole harness in or just take plugs? What plugs will i need? I have a complete uncut SI Harness but thinking about selling it and just going to the junkyard and cut plugs off a harness there... Thanks!
the only thing i would use from the SI harness in the round plug for the dizzy. other than that you dont need much. I would also grab the injector clips and resistor box. You could probably seel the SI harness thought and make some money. Go to the junk yard and get the stuff you need from a 88-89 integra. All of my DPFI to MPFI swaps i have used integra injector clips, resistor boxes and Dizzy plug. matter of fact, you could use the green plug from the integra for your cam angle sensor wires and keep the small square plug like it is on the DX harness.
goood luck!
goood luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by julioboostamante »</TD></TR><TR><TD CLASS="quote">the only thing i would use from the SI harness in the round plug for the dizzy. other than that you dont need much. I would also grab the injector clips and resistor box. You could probably seel the SI harness thought and make some money. Go to the junk yard and get the stuff you need from a 88-89 integra. All of my DPFI to MPFI swaps i have used integra injector clips, resistor boxes and Dizzy plug. matter of fact, you could use the green plug from the integra for your cam angle sensor wires and keep the small square plug like it is on the DX harness.
goood luck!</TD></TR></TABLE>
thanks
thanks
mike84 CRX-GTL
Sep 12, 2005 03:45 PM
dingusjt
Oct 9, 2003 06:02 AM
