Need a new door handle, which is pass. side?
Old Aug 26, 2008 | 07:25 PM
bb2prelude's Avatar
Default Need a new door handle, which is pass. side?
So somehow the mechanism that holds the outer door handle down broke, and now the handle just kind of hangs there... time to replace.
My question is.. which p/n is for the passenger side?
33151 027 1 HANDLE ASSY., R. FR. DOOR (OUTER)
or
33177 048 1 HANDLE, L. (OUTER)
illustration is here:
http://www.hondaautomotivepart...+LOCK
Thanks!
Old Aug 26, 2008 | 08:01 PM
Kronn 98SH's Avatar
Default Re: Need a new door handle, which is pass. side? (bb2prelude)
well that depends, which side of your car is the steering wheel on? Left or Right? If on the left, then passenger side is the right side. If steering wheel is on the right, passenger side is the left side. For determining left from right, place both hands in a fist, with palms away from you. Then extend both thumbs and index fingers. The one that makes an L is your left hand. The one that does not make an L is your right hand.
Old Aug 26, 2008 | 09:09 PM
Kronn 98SH's Avatar
Default Re: Need a new door handle, which is pass. side? (Kronn 98SH)
By the way, from the sounds of things, the handle could be off the spring or the spring is broken. Pull the door panel and check the mechanism before buying parts you might not need.
rabarbie
Jul 10, 2018 12:32 PM
PaNdA!!!
Apr 23, 2009 09:00 AM
Diao
Jan 10, 2007 04:29 PM
Deke
May 1, 2003 12:22 PM
