Fuel Pressure question - hondata
Old Aug 26, 2008 | 05:51 PM
ELSpool's Avatar
Default Fuel Pressure question - hondata
I know this sound ghetto, but im running hondata s100 with boost on the same tune for the past 3 years. Every fall the af's get a bit crispy (11.9-12.3's), and because there is no local tuner anymore, how much would a small bump in fuel pressure, say 1-3lbs at idle affect the entire fuel map? Im not overly concerned with idle and part throttle, more just wot.
thanks!
Old Aug 26, 2008 | 09:06 PM
mtber's Avatar
Default Re: Fuel Pressure question - hondata (ELSpool)
Yes it should effect the overall a/f ratio.
Old Aug 27, 2008 | 06:52 AM
ELSpool's Avatar
I know it's a tough question to answer, but how much would a small bump in pressure equate to? Anyone with past experience?
Old Aug 27, 2008 | 07:09 AM
Tomdata's Avatar
Default Re: (ELSpool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool &raquo;</TD></TR><TR><TD CLASS="quote">I know this sound ghetto, but im running hondata s100 with boost on the same tune for the past 3 years. Every fall the af's get a bit crispy (11.9-12.3's), and because there is no local tuner anymore, how much would a small bump in fuel pressure, say 1-3lbs at idle affect the entire fuel map? Im not overly concerned with idle and part throttle, more just wot.
thanks!</TD></TR></TABLE>
based upon your original question I am assuming you have a wideband on the car. Otherwise you would not know what the afr is in the fall. If this is true then I suggest you try bumping the pressure up a little and see what happens.
Old Aug 27, 2008 | 07:54 AM
ELSpool's Avatar
thanks, yes I have a wideband in the car, I'll see what happenes...I think it's finally time to up grade to s300 now
Old Aug 27, 2008 | 06:20 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool &raquo;</TD></TR><TR><TD CLASS="quote">thanks, yes I have a wideband in the car, I'll see what happenes...I think it's finally time to up grade to s300 now </TD></TR></TABLE>
Good Idea
Engine Management and Tuning
Apr 3, 2013 11:14 AM
reallycooleg
Apr 18, 2006 06:59 PM
calib17a
Apr 21, 2004 11:50 PM
ATgrills.com
Jul 24, 2003 07:38 AM
LOwrestling2001
Aug 16, 2002 11:21 PM
