Charcoal Canister Problem
Old Aug 26, 2008 | 04:36 PM
vshavoc's Avatar
Default Charcoal Canister Problem
Hopefully I can actually get a reply on this one. I have a obd2b gsr swapped into a 99 ls. I need to put a charcoal canister back on it. The bracket for the canister on the 2000 and 2001 obd2b engines is different and so are the diameter of the hoses.
Question: Can I use any 96-99 charcoal canister or does it need to be from a 99 only? Is there any difference between the 99 and 2000 canisters other than the bracket and hose diameters? Also, will the plugs be compatible for the purge solenoid from obd2b to obd2a?
Kevins89notch
Jul 8, 2014 05:40 PM
NA JDM GSR
May 23, 2006 07:10 PM
