d series clutch questions
Old Aug 26, 2008 | 04:12 PM
team2dcrx's Avatar
Default d series clutch questions
i thought all d series clutches were the same besides the 88-91 dx models..cause i have a crx with sohc zc and i just bought a flywheel for a dual cam zc and i was planning on puting it on my crx but when i look up clutches it says 88-89 are diferent from 90-91 and are also different from the 92-00...what makes them different?
Modified by team2dcrx at 5:30 PM 8/26/2008
Old Aug 26, 2008 | 05:51 PM
90sedan's Avatar
Default Re: d series clutch questions (team2dcrx)
88-89 have a 200mm flywheel.
90-00 have a 212mm flywheel.
Old Aug 26, 2008 | 06:31 PM
1990hondacrx's Avatar
i have a flywheel and new clutch for sale if u interested
Old Aug 27, 2008 | 10:34 AM
team2dcrx's Avatar
ok so when i get the flywheel should i measure it and the buy a clutch for that year... or does the clutch not matter...cause i had a clutch on lifetime warranty through autozone and my friend had a 91 and it worked fine in his crx
Old Aug 27, 2008 | 10:57 AM
90sedan's Avatar
Default Re: (team2dcrx)
The clutch needs to match the flywheel, otherwise it won't bolt on.
So you either need an 88-89 clutch & flywheel (Only 88 if the transmission is an 88)
Or 90-91 clutch with a 90-00 flywheel
Measure the flywheel and figure out which clutch you need.
Old Aug 27, 2008 | 03:37 PM
mario_pic's Avatar
Default Re: d series clutch questions (90sedan)
also a a 90 to 2000 flywheel is the same im runing a 96 civic flywheel on my 91 motori also had the clutch and press plate as well worked cazy stiff grabed well almost felt like a stage2 exedy and it was a stock exedy
Old Aug 27, 2008 | 03:42 PM
team2dcrx's Avatar
will im kinda confused cause i have a sohc zc with a 91 trans that i bought from a importer...and i used the 88 flywheel and a 91 clutch
Old Aug 27, 2008 | 06:47 PM
90sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by team2dcrx &raquo;</TD></TR><TR><TD CLASS="quote">will im kinda confused cause i have a sohc zc with a 91 trans that i bought from a importer...and i used the 88 flywheel and a 91 clutch</TD></TR></TABLE>
Why are you confused? Either switch the flywheel to a 90-91 (212mm) or swap the clutch to a 89 (Can't use an 88 because of the 21 spline count on the transmission, 89-00 have 20 splines).
Old Aug 29, 2008 | 12:19 PM
team2dcrx's Avatar
alright i got the flywheel and how do i measure it cause i measured it straight across and it was 11 inches=280 mm
Old Aug 29, 2008 | 01:45 PM
sanimalp's Avatar
$cat /dev/urandom
you need to measure the diameter of the contact area on the flywheel. and the 88's have a 190mm flywheel.. not 200 as quoted above..
here is the breakdown..
88 has 190mm flywheel and 21 spline input shaft trans
89 has 200mm flywheel and 20 spline input shaft trans
90-2000 d-series has 212mm flywheel and 20 spline input shaft trans
if you have a 20 spline transmission, you should just make your life easy and buy all 90+ parts, flywheel, clutch etc. the only thing different on the 92+ is they are hydro rather than cable. the clutch is exactly the same otherwise.
Old Aug 29, 2008 | 02:24 PM
team2dcrx's Avatar
alright i measured it...and it was like 215mm ish and then i tried putting the 91 pressure plate on it and it wont fit...so riddle me this one batman
Old Sep 2, 2008 | 11:24 AM
sanimalp's Avatar
$cat /dev/urandom
the pressure plate has some pin reliefs that fit the flywheel, which you then align to get everything to fit together. also, make sure the clutch disk is facing the right direction, otherwise you might have some trouble.
matt's hatch
Jan 30, 2010 06:03 PM
IntegraMastaz
Dec 13, 2005 05:26 AM
MurphDog74
Jul 24, 2002 08:31 PM
