check engine light no codes
Old Aug 26, 2008 | 09:25 AM
pellet36's Avatar
Default check engine light no codes
I have a 99 accord ex v-6 coupe. My meitenance req. light came on because of the 2nd clutch pressure fluid switch. I have replaced that and cleared the code but the light remains. any help here is and will be appreciated. Also every light in the car pulsates. even with the stereo off. could this be the voltage reg? related to my other problem? I replaced a corroded ground wire(neg. battery post to frame) and thought that was it. help me honda gods!
Old Aug 26, 2008 | 11:05 AM
pellet36's Avatar
Default Re: check engine light no codes (pellet36)
never mind! figured it out!
Old Aug 31, 2008 | 07:03 AM
JOE BD-0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pellet36 &raquo;</TD></TR><TR><TD CLASS="quote">never mind! figured it out!</TD></TR></TABLE>
OK, so please tell us what it was?....thanks.....JB
Old Aug 31, 2008 | 12:44 PM
pellet36's Avatar
My bad!I've never owned a car with a meitenence req. light before. I am not even sure if the code i origanally pulled was really a problem or not. I fixed it though, replaced the sec. clutch fluid pressure switch. It seems to shift better now but that could be my imagination. the chech engine light was not on, just the other one. holding in the odo. reset button while starting the car continuing to hold the button till the light went off. I'm new to this Honda thing so give me some time.
blackj30_a
Mar 30, 2016 11:20 AM
Argenis 2524
Feb 5, 2016 11:48 PM
Denise W Smith
Honda Civic (2006 - 2015)
Nov 9, 2012 11:05 PM
eL
Oct 25, 2003 05:25 AM
laurat
Oct 14, 2002 12:54 PM
