flux core mig welding
The only kinda available. It is called cored wire or something like that, I have a little spool at the shop. Never used it, never bought it so I don't know the trade name. Unless you are welding outside in really windy conditions, I would by the gas regulator and a bottle of gas. It will be mo' betta' in the end. In fact flux core wire is more expensive than the gas wire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteener »</TD></TR><TR><TD CLASS="quote">The only kinda available. It is called cored wire or something like that, I have a little spool at the shop. Never used it, never bought it so I don't know the trade name. Unless you are welding outside in really windy conditions, I would by the gas regulator and a bottle of gas. It will be mo' betta' in the end. In fact flux core wire is more expensive than the gas wire.</TD></TR></TABLE>
yea, i thought the welder i bought awhile ago what flux and gas, but i was wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One »</TD></TR><TR><TD CLASS="quote">I believe flux core wire is available in .028, .030, and .035". It's hard to find the smaller wire- which uses less heat</TD></TR></TABLE>
and what type of metals can be welded, just mild steel?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">
and what type of metals can be welded, just mild steel?</TD></TR></TABLE>
pretty much.
I've welded stainless- but you have to be careful. Flux core runs very hot and can burn through very easily.
pretty much.
