FS WTT: 2000 Civic Si $6500 EBP OHIO 92k Miles
Old Aug 26, 2008 | 04:14 AM
Bassicfun's Avatar
Default FS WTT: 2000 Civic Si $6500 EBP OHIO 92k Miles
2000 Honda Civic Si
92xxx miles
2 Owner (original owner is a friend of mine, also a Honda-tech person I believe)
Electron Blue Pearl
Hesitant to say mostly stock, but in relative terms, it is.
Modifications:
LIMITED SLIP DIFF [LSD]
KYB Adjustable shocks
Eibach Lowering Springs
AEM Cold Air Intake
APEXI 2.5" cat back exhaust [I also have an OEM type Axle back on it currently, you can have both]
FLIX 15x6.5" wheels with Yokohama tires
The 'Bad'
Some interior pieces missing [ask for specifics] such as passenger side handle above door, rear seat belts, trunk liners, pocket under the radio. (misc small pieces, maybe $100 and someone could find everything needed on ebay)
Small dent on driver's side door, dent on passenger side rear quarter panel.
The Good:
LSD Also again a two owner car, clean title, great mechanical condition, no vibration while driving, not pulling in either direction, cold A/C, mostly stock appearance.
The Price, Values average on KBB, NADA, Edmunds from $7800-$9000. $6500, and if someone wants all few missing pieces back in, it'd be $500 on the high end, and there's a low mileage SI for $7k
For the WTT part:
I'm looking for something higher end/luxury, surely compromising the performance I'm sure. Here's a few cars I'd look to trade even up for.
Acura RL [top choice]
Acura TL
Lexus 4 door automatic
Lincoln LS
Infiniti 4 door automatic
Audi [POSSIBLY, must be quattro and well taken care of]
Most of these I'm looking at late 90s to early 2000s, and seeing values and ones selling in the $6-7k range, so I'd more than likely be looking for an even up trade. Only real requirement is to not have modifications done, and preferrably black, silver or white.
I'll get pictures up of the civic in a day or two I imagine. Thanks
Contact me at 419.631.3912 or brian [at] crxmotorsports.com Thanks
Old Aug 26, 2008 | 09:59 AM
lowandslow's Avatar
hey man i would like to see some pics asap this could be what i am looking for
Old Aug 26, 2008 | 10:14 AM
Bassicfun's Avatar
Default Re: (lowandslow)
Quick pictures from today, after the bath. Thanks for the interest
Old Aug 27, 2008 | 06:12 AM
Bassicfun's Avatar
Thanks for all the PMs and interest
Old Aug 29, 2008 | 04:04 AM
Bassicfun's Avatar
Default Re: (Bassicfun)
Engine Pictures by request.
Old Sep 2, 2008 | 03:49 AM
Bassicfun's Avatar
incredible amount of interest, still for sale. .first with an offer, or should I say cash in hand, or vehicle in hand wins.
Old Sep 4, 2008 | 04:26 PM
Bassicfun's Avatar
Default Re: FS WTT: 2000 Civic Si $6500 EBP OHIO 92k Miles (Bassicfun)
Details and more...
I looked over the car last night some.. trying to be picky, so the list will below may sound bad, but just overly detailed/nitpicky for those with a 'drive' to get here that are making offers... I said in the post misc. pieces missing, but here is a list as I saw them last night. IF you are wondering about something inparticular please ask.
Missing:
Exterior:
part of the front fender liners
trim screw or two that helps hold on the license plate surround piece
Interior:
Entire trunk linings
Rear Seat hardware [seat belts, hinges, release]
rear speakers [all wiring is still present]
pocket under OEM radio [although the OEM CD player is included]
kick panel on drivers side
dome/map lights
passenger grab handle
Like I mentioned, probably $100 or so from someone on the forums and you could get it all.
the 'bad'
The Sunroof currently doesn't work, but all the pieces and parts are there. I guess to be more accurate.. the sunroof works, the wiring going to it was stuffed into an A pillar, so it isn't currently connected.
hood release broken (just the tab that you pull on, but it still pops the hood open as it should, and you just pull on it like you normally would)
tire or two needs balanced, no vibration in the wheel, but you can audibly hear it under braking and cornering.
Front upper control arms were replaced with some adj. ones. I have honda OEM upper control arms that I'll give with the car so you have your choice on the adj. or stock ones.
The good
Power windows, doors, keyless entry, etc all work fine. A/C blows cold, minus that clutch/pulley assembly that needs replaced as I mentioned previously.
All original paint
Water pump and timing belt replaced at approx 50k miles
brakes are in good shape all around
Other pictures of dings/dents, and other angles.... Hope to have this gone this week or next...
Old Sep 7, 2008 | 02:20 PM
Bassicfun's Avatar
http://cgi.ebay.com/ebaymotors...:1123
Old Sep 10, 2008 | 03:53 AM
Bassicfun's Avatar
as an update $6000 firm Thanks
Old Sep 17, 2008 | 05:42 AM
Bassicfun's Avatar
Closing on eBay today... $5700 takes it
sam95teg
Oct 19, 2009 10:12 PM
sam95teg
Aug 19, 2009 03:51 PM
Bassicfun
Sep 17, 2008 05:41 AM
BerlinaAP2
May 10, 2004 09:16 PM
