jdm crx sir air filter
I need to know if anyone has any idea what air filter from north america will fit in a jdm crx sir. I got the car and there was no filter in it. I tried the North American crx air filter and its not the right size.
I found online that k&n sells one with description: "crx, 1.6l, vtec, non-US" part no: 33-2061. Does anyone know if there is an oem or fram filter that matches that k&n, or if that k&n is even the right one?
i thought it must have the same filter as some honda/acura that was available in north america, but it appears not. So i'll either put a short ram or swap the airbox for an regular si one.
I decided against having a loud intake system and located an oem SiR intake box and tubing. I was lucky to get mine with a K&N.
Since there is a cross over, here's the info you need:
K&N-
33-2061 Product Specifications
Product Style: Unique Air Filters
Filter Re-Oiling Amount: 0.66 oz (20 ml)
Height: 1.188 in (30 mm)
Inner Wire: No
Outside Length: 9.875 in (251 mm)
Outside Width: 6.563 in (167 mm)
Top Style: Open
Weight: 1.3 lb (0.6 kg)
Product Box Length: 13.5 in (343 mm)
Product Box Width: 7.75 in (197 mm)
Product Box Height: 1.75 in (44 mm)
Also, here's a link to an ebay auction in case you have problems locating one...
http://i15.ebayimg.com/08/i/000/f0/93/ba87_1.JPG
K&N-
Inner Wire: No
Top Style: Open
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez »</TD></TR><TR><TD CLASS="quote">did you have this at the miramichi a couple weeks ago?</TD></TR></TABLE>
I just got the car last tuesday. There are 3 that i know of in Moncton NB, a grey and black (different body panels) and two black ones mine plus a glass top.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz »</TD></TR><TR><TD CLASS="quote">I decided against having a loud intake system and located an oem SiR intake box and tubing. I was lucky to get mine with a K&N.
K&N-
I have a couple calls in to local shops to get me this filter and i used the cross reference on the k&n site and it appears that there is no disposable air filter that matches this size, all the cross referenced ones are for north american crx.
Its gonna take a couple weeks for the k&n to arrive, in the mean time i think i can get an si aribox to use.
Thanks for the replies.
K&N-
allmotorsircrx
23
Aug 12, 2010 08:34 AM
1slowcrx
Jan 25, 2008 03:22 PM
Spaceballsthelunchbox
Sep 29, 2001 02:06 AM
