Droppin a SOHC ZC into my Stock Dx
Old Aug 25, 2008 | 09:01 PM
The Rs's Avatar
Default Droppin a SOHC ZC into my Stock Dx
First thing's first- I tried to look up this information but I simply can't find it. If you don't want to help me, fine, but don't bother to try to insult me because you'll only be wasting our time.
Now- I'm going to drop a SOHC ZC into my STOCK CRX DX. I know I have to do the DPFI TO MPFI conversion and that I have to get a different ECU But what all am I going to need for the conversion if I'm getting this from Hmotorsonline
- Motor
- Intake Manifold
- Exhaust Manifold
- Injectors
- Fuel Rail
- Throttle body
- Alternator
- Distributor
- 5 Speed ZC Transmission(Add $200)
- Motors
Can I use the Intake Manifold and Throttle Body that I'm getting from them for the DPFI TO MPFI conversion or do I need an Si version of both? Dumb question? Maybe, but I want to be sure I get this right. This is my first swap. Also, what else would I need? What am I not getting from them that I will absolutely need? If you can drop some links with some info or products you think I'll need I'd appreciate it.
Thank you.
Old Sep 22, 2008 | 10:15 PM
crimsondeeep123's Avatar
i have a sohc zc and swaped it into my 90 civic hatchback dx and i did not have the ecu so wat i did was i put the intake manifold which was the dpfi and it fit on the zc so all i did was but the d15b2 parts in the zc and works great
Old Sep 22, 2008 | 10:23 PM
llslick's Avatar
Default Re: (crimsondeeep123)
Just swap intake manifolds and you are good to go go MPFI more power more fuel efficient
Old Sep 23, 2008 | 10:43 AM
0_civic_4's Avatar
Default Re: (llslick)
dont do that youll lose HP you want the runners off the intake on the zc
essay0ns
Apr 17, 2015 05:52 PM
91_zcjamie
Dec 3, 2008 11:45 AM
All Motor Chick
Oct 10, 2005 05:48 PM
MUGENKHID
Jul 1, 2005 06:40 PM
Ding
Apr 8, 2005 11:20 AM
