Huge sale- turbo parts, ecu, motors, sensors, cable to hydro conversion and more
Everything is O.B.O. so don't be afraid to make offers!!!!!
red dizzy rotor- b series (new) - 5$
black dizzy rotor- d series - 3$
EG hazard switch - 5$
EG dimmer switch - 5$
EF injector resistor box - 7$
OBD1 NGK o2 sensor - (like new) 10$
Type R throttle cable - (mint) 15$
Z6 THROTTLE BODY W/ tps - 20$
OBD1 PO6 VIRGIN ecu - 65$
OBD1 D Series AC compressor X 2 - 15$ ea.
Ls fuel line - 10$
D series fuel line - 10$
obd1 D Series IACV- 10$
D Series starter - 20$
D series tranny brackets - X 2 15 ea.
Innovative mounts cable to hydraulic conversion - (Brand New) 165$
OBD1 MAP sensor / 1 top mount, 1 firewall mount - 15$ ea.
OBD1 TPS sensor - 10$
OBD1 purge selenoid - 5$
D16Z6 wiring harness v-tec plugs cut off rest in tact 75$
obd1 cx harness good for plugs 15$
92-95 HB tailights (clean) 30$
92-95 halo headlights 30$
stock sohc exhaust manifold w/ O2 sensor 15$
OEM d series heat shield - 5.00$
D series tom cam gear cover x 2 5.00$ ea.
SOHC non- v valve cover (ready for paint) 15.00$
18 V cordless drill and charger 25.00$
Lower plastic valance for EG 10.00$
Sprint X-Large helmet ( good for trsck use) 25.00$
Old school rockford amp 25.00$
D series oem clutch, pressure plate and fywheel 25.00$
D15B8 long block, needs timing belt, and a few sensors 100.00
D series p20 dx/cx trans no grinds 150.00
NES Nintendo w/ ac adapter and 1 controler 35.00$
MAKE OFFER!!!!!!!
Mild build D16Z6 w/ good ex trans
Skunk2 pro series IM
3 layer head gasket
ARP Headstuds
pm7/p29 11.5:1 comp (nippon)
block gaurd
ACL rod and main bearings
nology wires
header
stage 2 clutch w/ 7.5 lb flywheel
intake
new cap and rotor
head is ported
NEW axles
all new gaskets, from the bottom up
new timing belt and tensionor
new oil pump
wiring harness
p28 chipped on crome
clean good running swap has about 3500 miles on it, there might be things i missed but thats the basic rundown.
Humor me with some offers and no part outs on the z6 swap!!!!!!!!!!!
More parts to come as i pull the car apart for paint.
Please when you PM me specify the part and if you need shipping!!!!!!!
THANKS H-T
Modified by EGfreek at 10:13 PM 8/29/2008
Modified by EGfreek at 1:07 AM 9/13/2008
Modified by EGfreek at 7:16 PM 9/22/2008
Ls fuel line - 10$
MAKE OFFER!!!!!!!
3 layer head gasket
ARP Headstuds
block gaurd
nology wires
header
intake
new cap and rotor
head is ported
NEW axles
new oil pump
wiring harness
THANKS H-T
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyounin608 »</TD></TR><TR><TD CLASS="quote">Mileage on the b8 longblock? </TD></TR></TABLE>
PM'ED YOU!!!!!
PM'ED YOU!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dx_blk_hatch »</TD></TR><TR><TD CLASS="quote">would u want to trade your motor for a la turbo motor?...u get every thing u need</TD></TR></TABLE>
pm me with more details on the motor and turbo kit.
