Rough Idle - Code 3 obd0 MAP Sensor > obd1 engine
Old Aug 25, 2008 | 06:59 PM
ketchup's Avatar
Default Rough Idle - Code 3 obd0 MAP Sensor > obd1 engine
Started up the 91 CRX HF after it's been sitting around this weekend. Took longer than expected (battery might have been drained some). After it finally turned over, it was idling rough. Then the check engine light came on, checked the code and found it to be 3 blinks = Manifold Absolute Pressure (MAP Sensor). Vacuum lines checked, wiring checked, and I'm considering replacing the map sensor then starting from square 1 again, maybe even replacing the vacuum lines with new ones.
Since the motor is obd1, should I take this opportunity to convert to an obd1 map sensor? If that still doesn't fix it, where should I be looking for a problem?
Old Aug 25, 2008 | 08:10 PM
Crx Jimmy's Avatar
Default Re: Rough Idle - Code 3 obd0 MAP Sensor > obd1 engine (ketchup)
either map will function the same, I would just use the one on the firewall
Old Aug 25, 2008 | 09:03 PM
ketchup's Avatar
Default Re: Rough Idle - Code 3 obd0 MAP Sensor > obd1 engine (Crx Jimmy)
What do I need to do to get to the bottom of this?
Old Aug 26, 2008 | 11:27 AM
ketchup's Avatar
fixed the pos connector.
liftdhatch95
Feb 9, 2008 02:00 PM
BoRiCuA
Jun 30, 2004 06:06 AM
DAMCOOLDAV
Sep 12, 2003 02:05 PM
