swapping OBD2 H22 into OBD2 integra
I have a friend who has a 95-98 prelude front cut ( i think that is the year spand). If i am correct this motor is OBD2.
He wants to sway it into a 98 Integra which came with a Fuel injected non-vtec SOHC motor.
We want this swap to be as painless as possible, but i dont have much knowledge of what is needed to make his swap successful. ( I have dont swaps b4 but never a H22 into anything) .
What does he need ?
Is that model prelude OBD2?
what does he need to do where wiring is concerned?
What does he need ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6madness »</TD></TR><TR><TD CLASS="quote">I have a friend who has a 95-98 prelude front cut ( i think that is the year spand). If i am correct this motor is OBD2.
What does he need ?
ok first off no obd2 integra came sohc
What does he need ?
lord, if someone didnt say that i wouldnt know my name ..... i am not asking you i know what i am saying ...the car is a direct import from Japan and RHD. the motor in the car is an OBD2 SOHC D16. ....
so once again i want to know what he will need to get the motor in the car. and what will he need to get the car right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NirVTEC »</TD></TR><TR><TD CLASS="quote">SOHC D16 in a Teg? Thats a 1st.....
If its an obd2 H22, it was either a 96 or 97-01 clip.</TD></TR></TABLE>
Yeh, i am not fm teh US, and alot of the tegs that are imported here are SOHC tegs, very few come in GSRs. and even more rear is the LS/gs B18B, ( you cant fine those at all). Even my EG the chasis code is EG4 not EG6 like you guys and it is called VTi.
I have heard u guy in the US say the the OBD2 civic comes with a one piece harness that runs form teh motor in to the car. I put a B18C in my boys EK and his had 2 piece, i never seen a one piece.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker »</TD></TR><TR><TD CLASS="quote">Isnt the H22 fuel injected to begin with?</TD></TR></TABLE>
Yeh it comes fuel injected. I never said it doent, i made reference to the fuel injected SOHC so that i can get help on how to wire the H22 i am helping him put in.
So i wanted to know if the entire swap needed to be rewired or do i just run the wires fro the VTEC, EGR, Knock sensor and whatever else?
What do i do
What do i do
What do i do </TD></TR></TABLE>
Well I cant tell you that. Although your best bet is to compare ECu pin out charts from each ECU. There is the P13 pinout chart in the FAQs.
JBirch_97Prelude
Sep 26, 2007 01:43 PM
