Bought OEM brake pads for my rsx-s. GREASE PACKET??
Old Aug 25, 2008 | 05:50 PM
h8ted ek's Avatar
Default Bought OEM brake pads for my rsx-s. GREASE PACKET??
What Im asking is this grease thing that came with the brake pads.
How do I apply it?
I am thinking it goes between the brake pad and the metal bracket as a cement glue. is that right? or does it go on the brake pads itself, that help with squeal?
Any inputs would be great, Thanks.
Old Aug 25, 2008 | 06:43 PM
risktypeS's Avatar
Default Re: Bought OEM brake pads for my rsx-s. GREASE PACKET?? (h8ted ek)
You know how the pads attach to the caliper via a plate-and-clip arrangement? The lubricant goes between the plate and the back of the brake pad. not on the front of the pad, which comes in contact with the rotor, but on the back.
Old Aug 25, 2008 | 06:46 PM
_BEN_'s Avatar
The grease you have is commonly referred to as anti squeal.
It goes in between the shim and the back of the brake pad and it helps prevent squeaky brakes.
Do not under any circumstances apply it to the side of the brake pad that makes contact with the rotor. Try to keep your dirty hands off of that side of the pad and the rotor as well.
Old Aug 25, 2008 | 08:11 PM
blacK20's Avatar
Default Re: Bought OEM brake pads for my rsx-s. GREASE PACKET?? (_BEN_)
Make sure the pins are lubed as well. Far more important than the back of the pads.
Old Aug 26, 2008 | 04:18 AM
turboteg2nv's Avatar
Default Re: Bought OEM brake pads for my rsx-s. GREASE PACKET?? (blacK20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacK20 &raquo;</TD></TR><TR><TD CLASS="quote">Make sure the pins are lubed as well. Far more important than the back of the pads.</TD></TR></TABLE>
x2. Truth
rjmq06
20
Oct 22, 2009 11:58 AM
vtec128
Oct 20, 2009 07:57 AM
InTeGrA_bLazEd
Oct 14, 2003 12:47 AM
kent
Mar 17, 2003 04:24 PM
