D series swap q's... D15B to D16Z6
Old Aug 25, 2008 | 05:45 PM
DCRB's Avatar
Default D series swap q's... D15B to D16Z6
Ok couple of q's here for this swap that i'm doing.
I have a fully running (w a blown HG) D15B in an 89 hatch. that's all that's stamped on the motor.
going to a d16z6 from a 95 civic hb, that's going into annother 89 hatch that i have
my q's are:
can i use my ac stuff from the d15 on the d16?
I have the alternator bracket for the d16, but are those parts swapable?
Waterpump - there's a new one one the d15, can i swap that?
and most importantly, wiring harness: if i bought a harness and ecu for the d16, would i have to still chop and splice, or could i use the whole engine harness?
the harness that's got the ecu plugs on one end that goes from the cabin to the engine bay is one harness, and the harness that goes from the engine is called the engine sub harness right?
Thanks for helping me answer my q's. i will search this stuff as well, but didn't find really anything on the ac
Old Aug 25, 2008 | 06:04 PM
hondarat's Avatar
Default Re: D series swap q's... D15B to D16Z6 (DCRB)
everything will swap over.. as long as you have a mpfi setup you dont need to change the harness. if its a d15b its vtec and everything is plug and play.
Old Aug 25, 2008 | 08:29 PM
DCRB's Avatar
Default Re: D series swap q's... D15B to D16Z6 (hondarat)
well that's just it's a dpfi and a non vtech head.... as far as i know this engine insn't the origonal... aw heck as far as i know none of the front end is origonal.
Nando-tech
Lighting
Jul 19, 2014 11:14 AM
jisu009
Apr 1, 2004 07:43 AM
SOHC_Brian
Dec 5, 2003 09:38 AM
SOHCEK-Turbo
Aug 12, 2003 01:41 PM
