FS: '93 Civic EG hatchback - fully track prepared car - 2.0L GS-R motor - 240whp
Old Aug 25, 2008 | 05:17 PM
EleanoR's Avatar
Default FS: '93 Civic EG hatchback - fully track prepared car - 2.0L GS-R motor - 240whp
I have decided it’s time to take a different direction in my life at this point which is forcing me to sell my dream Honda that I have been building over the past 3 years. It's time to pass that dream along to someone else.
It is setup to be a HPDE car and/or a NASA TT car (you choose the class and make further modifications, etc). I am in no rush to sell and won’t be taking trades of any sort. I do however ask that if you are genuinely interested in purchasing the vehicle that you e-mail me your contact information so I can keep a database of who has contacted me.
This Civic horsepower to weight runs all day with a lot of high end cars including Corvette’s, Porsches, BMW’s, and Mercedes. It put down 244/155 to the front wheels and weighs just over 2100 lbs with a ¼ of fuel. It is an absolute blast to drive as you can imagine and turns many heads. This car will get you attention in a positive way. Engine build sheet directly from King is available as they keep meticulous records of what engines they build and for who.
I have had many different people who will chime in on this thread drive the vehicle both on the street as well as the track who can vouch that it’s legit.
Included are the specifications of the car along with pictures and video. If you have any further questions please contact me at Mmaudlin@maudlinintl.com
I have a 20ft Enclosed Car Hauler (Pace Rallye) that is available as well should the price be right to be able to have a turn key weekend warrior.
I don't have an outright asking price since this car is so highly modified. Reasonable offers will be responded to and the VIN will be provided the moderator upon request.
Many extras come with this car that are not mentioned in this thread include a spare set of Gator axles (newly rebuilt). Inquire within for more information.
CAR SPECS – 1993 Civic DX Hatchback – 230whp – 2100 lbs Dry
•Tuned By MASE in Jacksonville, FL
•244/155 @ 9,300 RPM
Engine -
Bottom End:
-B18C (GSR) Block
-Golden Eagle Sleeves
-Carillo Rods
-Wiseco 2cc Pistons
-OEM Bearings, Pumps, Gaskets (Cosmetic head gasket)
-Balanced/Blueprinted
-King Motorsports Super-finishing and Anti-Friction Treatment
-Moroso 20910 Pan
Top End:
-King Stage IV Head Work
-Supertech Valvesprings/Retainers
-Skunk Pro2+ Cams
-Skunk Pro Series Manifold w/ King Coolant Bypass
Transmission:
JDM ITR Transmission W/ USDM 4th and 5th Gear Swap W/ Internal Parts Super Friction Coated
•Custom 3’’ Stainless Intake Wrapped In Header Wrap
•Rage Big Tube 2.0L Header
•Megan Racing Adjustable Cam Gears
•B&M Fuel Pressure Regulator Gauge
•AEM Fuel Pressure Regulator
•AEM Fuel Rail
•Endyn Oil Catch Can
•Microtech Standalone ECU
•Exedy Organic Clutch
•Exedy Lightweight Flywheel
•Innovative Engine Mounts
•Full 2.5in Race Exhaust by Magnflow W/ Turndown
•NGK Spark Plug Wires
•Hondata Intake Manifold Gasket
•Setrab 24 Row Oil Cooler Ducted
•Greddy Sandwich Plate Adapter
•Bored ITR Throttle Body 64.5 Tapered to 70
•Fluidyne Full Length Radiator
•FAL SlimLine Fan
•Walbro Fuel Pump
•RC 440 Injectors
•Energy Suspension Shifter Bushings
•BPI Flow Stack
•Fluidampr Crank Pulley
•Stock Axles Re-Worked by Gator Axles With Breather
Gas
•93 Pump
Gauges – Custom Cluster Setup
•Autometer Oil Pressure
•Autometer Oil Temperature
•Autometer Water Temperature
•Autometer Fuel Level Gauge
•Autometer Tachometer
Suspension
•Full Type R Front And Rear With 5 Lug Conversion
•Pic Performance Suspension (modified with rates of 580/680)
•A-Spec Racing Rear Subframe Reinforcement
•ITR Rear Swaybar 22mm
•Type R Front Swaybbar
•Neuspeed Front Strut Bar
•Cornerweighted
•-3.0 Camber Front/-2.5 Camber Rear 1/16th Total Toe Out Front & 1/16th Toe In Rear
•Skunk2 Front Camber Kit
•Omnipower Rear Camber Kit
•ARP Wheel Studs
•Mugen Rear Trailing Arm Bushings
Removed Items
•Car Is Fully Gutted
•NO AC/PS/Heat
•Removed Drivers and Passenger Side Windows
•Removed Rear Wiper
•Removed Front Bumper Brace
•Removed Sound Deadening
•Removed Front Wiper System
•Interior Doors Cut Out
•Removed Engine Torque Mounts
•FAL Lexan Windows (Back 3)
Safety
•MazWorx Custom 6 Point Cage w/ Nascar Door Bars
•G-force 5 Point Harness
•Battery Kill Switch
•Sparco Hood Pins
•HANS Device
•Mugen Tow Hook
Interior
•Sparco Lap 5 Steering Wheel
•Sparco Quick Disconnect
•Proform Adjustable Shift Light
•Momo Cup GT Passenger Seat
•Racetech Driver Seat
•Genuine Type R shift ****
•Fastline Shifter
•Sparco Carbon Fiber Pedals
•Summit Battery Relocation Kit
•Longacre Igntion & Pushbutton Start
•SPA Digital Speedometer
•Buddy Club Battery
•IOport Camera Mount
•Sparco Dead Pedal
Brakes
•Tilton Adjustable Rear Brake Prop Valve
•ITR Brakes Front/Rear
•Brembo OE Replacement Rotors (Front And Rear)
•Integra RS Brake Booster
•Integra RS Brake Master Cylinder
•Carbotech XP12 Front Brake Pads
•Carbotech AX6 Rear Pads
•Stoptech Stainless Steel Brake Lines
•MOTUL RBF600 Brake Fluid
•Removed All Dust Shields
•Brake Ducting (Front Only)
Aerodynamics
•Import Precision Carbon Fiber Hood
•Air Dam / Splitter built by Scott Branham
•J’s Racing Canards
•Civic VX rear splitter $45
•Cwest GT Wing II Aluminum Single Flap (Brackets From Special Projects Motorsports)
Wheels/Tires
•Rota Slipstream 15x7 Wrapped in Toyo RA-1 225/45/15 Front and 205/50/15 Rear
•Volk Racing CE28 Forged 15x7 Wrapped in Toyo RA-1 225/45/15 Front And 205/50/15 Rear
PICS:
The splitter does have some scuff marks on it now but is still functional. Here's what it looked like brand new.
Here's a video of it on track at Sebring.
http://videos.streetfire.net/v...2.htm
As you can tell from the pictures and video the car is meticulously maintained and I have many vouches here on HT who have ridden in or driven the car themselves.
Thanks,
Mike
Modified by EleanoR at 7:09 PM 8/25/2008
Old Aug 25, 2008 | 06:08 PM
RStoR's Avatar
Default Re: FS: '93 Civic EG hatchback - fully track prepared car - 2.0L GS-R motor - 240whp (EleanoR)
Great seller! Great car!
Old Aug 25, 2008 | 06:26 PM
neof69's Avatar
Default Re: FS: '93 Civic EG hatchback - fully track prepared car - 2.0L GS-R motor - 240whp (RStoR)
This car is nasty!!
Old Aug 25, 2008 | 07:16 PM
eternal135's Avatar
Default Re: FS: '93 Civic EG hatchback - fully track prepared car - 2.0L GS-R motor - 240whp (neof69)
that video was sweet. awesome car
Old Aug 25, 2008 | 08:00 PM
SanFranGunners's Avatar
Default Re: FS: '93 Civic EG hatchback - fully track prepared car - 2.0L GS-R motor - 240whp (eternal135)
Very Impressive.. Bump for you, sir..
Old Aug 25, 2008 | 08:30 PM
drewbie*'s Avatar
such a sick car gl with the sale
Old Aug 25, 2008 | 09:11 PM
MikeSarr_GSR's Avatar
Default Re: FS: '93 Civic EG hatchback - fully track prepared car - 2.0L GS-R motor - 240whp (drewbie*)
I will always remember the sound of this car going down the back straight at sebring!
Glad I got to drive it
Someone needs to scoop this sucker up quick!
Old Aug 26, 2008 | 01:09 AM
JayDeeEmm's Avatar
sweet hatch sounds great too
Old Aug 26, 2008 | 04:02 AM
RoadRacer46's Avatar
I can't believe you are selling the car.
If anyone is looking for a a very capable track car, look no further. This car is incredibility fast.
Good luck with the sale.
Old Aug 26, 2008 | 04:12 AM
Dave_B's Avatar
Fast car and awesome seller.
GL man!!!
Old Aug 26, 2008 | 06:27 PM
EleanoR's Avatar
Default Re: (Dave_B)
thanks for the compliments
Old Aug 26, 2008 | 09:57 PM
BOOSTED LS EG's Avatar
Default Re: (EleanoR)
wow. very impressive car. Your driving skills are also up there.. VERY NICE!!
Old Aug 28, 2008 | 05:40 AM
bump for mike
SlowB16
30
May 6, 2013 04:02 AM
EleanoR
Jan 30, 2009 05:54 PM
Maxi
Dec 3, 2008 06:11 PM
JDtiM
Jun 30, 2005 05:28 PM
