Civic front end onto an Integra? A little different...
Old Aug 25, 2008 | 04:01 PM
paton5g's Avatar
Default Civic front end onto an Integra? A little different...
I was thinking about front end swaps today... I used to have a 93 Civic Coupe with sweet one piece projectors. I have a 96 Integra now and wanted to do the JDM front end... but everyone's done it and I thought a Civic front end might look alright on a Teg. Silly idea? Can this be done (easily)?
Old Aug 29, 2008 | 09:55 AM
VeeL_B20's Avatar
Default Re: Civic front end onto an Integra? A little different... (paton5g)
Seen it done vice-versa so why not!!! GOOD LUCK!!!
Old Aug 30, 2008 | 07:24 PM
B18GLC's Avatar
I think that would look sick, give it a shot.
Old Oct 5, 2008 | 09:24 AM
runvegas's Avatar
i want to see pictures of this.............
Old Oct 5, 2008 | 07:09 PM
DynastyRacer22's Avatar
dooo it man its gonna be hella tight make sure its an oem front end with jdm parts lol jk i know its gonna get all crazy in this thread soon
Old Oct 5, 2008 | 08:35 PM
kra95teg's Avatar
i think the core supports are different and thats about it all the other parts bolt up
Old Oct 6, 2008 | 11:03 AM
Tight R's Avatar
radsupport is different.
also civic front end is shorter.
you will have to cut and join the fenders using the civic front and integra rears. the side aprons on the body needs to get cut and redone using civic aprons and the new rad has to get welded on in an angle to accomadate the new location of the hood latch and fender area.
imo unless you have 3500 for this conversion dont both wasting time as its costly and time consuming to do is properly
Old Oct 8, 2008 | 02:17 PM
paton5g's Avatar
Default Re: (Tight R)
thanks for the feedback guys. i was just entertaining the idea... but it sounds like a lot work. i was under the impression that a lot of the parts would be bolt up.
but i did see the rad support as an issue. too bad though, might be a pretty bad *** look.
Old Oct 8, 2008 | 07:52 PM
runvegas's Avatar
Default Re: (paton5g)
the rad sits up into the frame ( up by the hood) of the car more than the integra. it will work, the big part is the fenders. they have to be cut, and re- welded together. i'm doing a civ hatch with a integra front. so i'm seeing the diff with this.
Old Oct 8, 2008 | 08:49 PM
mfef4dr's Avatar
Don't do it
Civic-Kids
Paint and Body
Nov 8, 2009 12:36 PM
djquick
Jul 18, 2006 10:57 AM
Chassis Guru
Feb 20, 2006 05:16 PM
projekt4dr
Aug 4, 2004 10:49 PM
blacksheep
59
Jan 28, 2003 10:49 PM
