Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
what intake should i get........
Old Aug 25, 2008 | 01:33 PM
cangriSi's Avatar
Default what intake should i get........
what intake should i get....... injen, fujita, aem, k&n. short ram or cold air......
Old Aug 25, 2008 | 02:12 PM
-Gambit-'s Avatar
Default Re: what intake should i get........ (cangriSi)
they are alll pretty much the same out of those brands. How much better can another company make a tube with a filter on it then another company, really?
but between a short ram and cold air, get the cold air.
Old Aug 25, 2008 | 03:20 PM
SIVIC 3's Avatar
where is the smiley shooting himself in the head emoticon?
all this was found searching intake:
My Profile | Member List | iServe | Garage | Search
You are logged in as SIVIC 3, Log out | Recent Topics
Honda-Tech.com » Search » 11 topics found
» Search Results
Your search for intake returned 11 results.
» New Search
Sponsored Search Results
Topic Forum Date Posts
Weapon R Intake
Forum » Honda Civic (2006 - Current)
Creator » 07SIcpe 10:48 AM 8/24/2008
by 2008fijibluesi 4
injen intake i`ve searched but nt .......
Creator » p3terson17 10:07 AM 8/24/2008
by SIVIC 3 9
short ram intake...
Creator » knaira112387 1:11 PM 8/21/2008
by 100miles+ 7
Short Ram Intake Question.
Creator » knaira112387 10:38 AM 8/10/2008
by 25RFG2 3
Intake/Headers/Exhaust for 2008 Civic
Creator » ferio252 4:20 PM 7/24/2008
by SIVIC 3 5
Trade me your short ram intake for my cold air??
Creator » Honder07si 9:45 PM 7/21/2008
by Honder07si 14
intake for K20Z3
Creator » mugensi_08 3:48 PM 7/19/2008
by BeauHance 8
FS: Nearly new CT (Comptech Engineering) Supercharger Kit, Vibrant header and exhaust, Injen intake,
Creator » Back in Black 6:15 AM 7/2/2008
by Back in Black 2
K&N V2 intake, whose got it?
Creator » invisible 5:00 PM 6/19/2008
by KlickityClack07 15
prefered aftermarket intake/exhaust for 2008 civic si sedan
Creator » USjdm 2:21 PM 6/8/2008
by USjdm 3
Intake ( 1 2 )
Creator » DanielleRodavich 11:50 PM 6/7/2008
by Socali914 27
Powered by ZeroForum 2.1.2b. ©2008 RelyNet, Inc.
Old Aug 25, 2008 | 06:37 PM
RICO_'s Avatar
NO MERCY!
Default Re: (SIVIC 3)
Old Aug 25, 2008 | 11:15 PM
i-VTEC_DOHC's Avatar
^^well if thats the case, why do aem intakes throw cel's when injen's do not??
Old Aug 25, 2008 | 11:20 PM
K5^'s Avatar
K5^
Brand New
Default Re: (i-VTEC_DOHC)
^Fixed.
, i didn't even consider that when I initially posted.
Old Aug 26, 2008 | 12:15 AM
Default Re: (K5^)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K5^ &raquo;</TD></TR><TR><TD CLASS="quote">^Fixed.
, i didn't even consider that when I initially posted.</TD></TR></TABLE>
its all good. but the reason being is that the aem changes the velocity of the air before the maf sensor, so therefore you throw a cel. the injen changes the velocity after the maf sensor so the maf sensor is reading the correct air velocity, but in reality the velocity changes after the maf sensor. i believe that the piping diameters are the reason behind this.
Old Aug 26, 2008 | 12:40 AM
SoCal07Si's Avatar
Ive had mine for a year and never thrown a CEL...damn people and their bunk info/lame install skillz
Old Aug 26, 2008 | 05:33 AM
IT GUY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i-VTEC_DOHC &raquo;</TD></TR><TR><TD CLASS="quote">
its all good. but the reason being is that the aem changes the velocity of the air before the maf sensor, so therefore you throw a cel. the injen changes the velocity after the maf sensor so the maf sensor is reading the correct air velocity, but in reality the velocity changes after the maf sensor. i believe that the piping diameters are the reason behind this.</TD></TR></TABLE>
any real info to back up this statement? MAF reads air velocity now, eh?
Old Aug 26, 2008 | 09:25 AM
MiX's Avatar
MiX
i got the AEM, b/c they came out with a new version that has veins for the MAF sensor and it comes with a new radiator hose to help clear the piping. Great intake.
MiX's Avatar
MiX
also no CEL
Old Aug 26, 2008 | 09:37 AM
IT GUY's Avatar
Default Re: (MiX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiX &raquo;</TD></TR><TR><TD CLASS="quote">i got the AEM, b/c they came out with a new version that has veins for the MAF sensor and it comes with a new radiator hose to help clear the piping. Great intake.</TD></TR></TABLE>
got pics of those "veins" ?
Old Aug 27, 2008 | 11:39 PM
it measures air flow. obviously velocity of air, as well as temperature and how dense the air is. the 2nd o2 sensor reads the exhaust flow. if the 2 arent reading the same, it throws a cel.
Old Aug 28, 2008 | 09:44 AM
MiX's Avatar
MiX
Default Re: (IT GUY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY &raquo;</TD></TR><TR><TD CLASS="quote">
got pics of those "veins" ?</TD></TR></TABLE>
http://www.8thcivic.com/forums....html
Old Aug 28, 2008 | 10:45 AM
IT GUY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i-VTEC_DOHC &raquo;</TD></TR><TR><TD CLASS="quote">it measures air flow. obviously velocity of air, as well as temperature and how dense the air is. the 2nd o2 sensor reads the exhaust flow. if the 2 arent reading the same, it throws a cel.</TD></TR></TABLE>
Ok. let's break it down. Easy to find definitions here.
Mass: "Mass is a fundamental concept in physics, roughly corresponding to the intuitive idea of how much matter there is in an object." http://en.wikipedia.org/wiki/Mass
Velocity: "In physics, velocity is defined as the rate of change of position. It is a vector physical quantity; both speed and direction are required to define it." http://en.wikipedia.org/wiki/Velocity
Mass Airflow Sensor: "mass airflow sensor is used to find out the mass of air entering a fuel-injected engine. The air mass information is necessary for the engine control unit (ECU) to balance and deliver the correct fuel mass to the engine" http://en.wikipedia.org/wiki/Mass_flow_sensor
Oxygen Sensor: "An oxygen sensor, or lambda sensor, is an electronic device that measures the proportion of oxygen (O2) in the gas or liquid being analyzed." http://en.wikipedia.org/wiki/Oxygen_sensor
MAF don't measure velocity.
O2 sensors don't measure flow.
Both sensors can't have the same reading, like you suggested, because they don't measure the same things.
Thanks for the pic MiX. Looks remarkably similar to the OEM housing
Old Aug 28, 2008 | 12:15 PM
NirVTEC's Avatar
Is there an answer to this question somewhere?
Is smart money just spent on an Injen?
Old Aug 28, 2008 | 06:02 PM
RICO_'s Avatar
NO MERCY!
Okay nerd. I have a riddle for you.
Some months have 30 days....and some months have 31 days.....But how many months have 28 days??
Old Aug 28, 2008 | 10:20 PM
pd0019's Avatar
Default Re: (RICO_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RICO_ &raquo;</TD></TR><TR><TD CLASS="quote">
hmmm tricky tricky LOL
injen's intake doesnt throw the CEL b/c they adjusted the piping diameter right around the MAF so that it wouldn't throw the CEL. there is ONE VERY knowledgeable person on this forum, wont give his name out, who knows everything there is to know about injen's intakes...i think he has posted in our forum once or twice.
Old Aug 29, 2008 | 02:21 AM
RICO_'s Avatar
NO MERCY!
Default Re: (pd0019)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pd0019 &raquo;</TD></TR><TR><TD CLASS="quote">
So what's the answer??
Old Aug 29, 2008 | 03:38 AM
IT GUY's Avatar
Default Re: (RICO_)
All months have 28 days, some just have more
Old Aug 29, 2008 | 04:56 AM
RICO_'s Avatar
NO MERCY!
I hate you.
Old Aug 29, 2008 | 02:07 PM
bmxmacdaddy's Avatar
aem had the biggest gains in a article i read, but still not much. i would rather spend the 2 or 3 hundred on something else...like a hooker
Old Aug 29, 2008 | 03:05 PM
RICO_'s Avatar
NO MERCY!
Default Re: what intake should i get........ (bmxmacdaddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmxmacdaddy &raquo;</TD></TR><TR><TD CLASS="quote">aem had the biggest gains in a article i read, but still not much. i would rather spend the 2 or 3 hundred on something else...like a hooker </TD></TR></TABLE>
...because the only way for you to get laid is to PAY for it??
Old Aug 31, 2008 | 10:18 PM
slouies's Avatar
i think my next intake goin to be injen short ram. i sold my aem cold air intake
Old Jan 2, 2009 | 11:55 PM
invsta's Avatar
I have a Fujita SRI uninstalled. I NEED TO KNOW NOW!...Does SRI improve performance above the stock intake system on an 08 SI??? Should I just insert a sportier filter into my stock box?
frog169
May 26, 2006 03:09 PM
Cannuck 94
16
Dec 30, 2005 11:30 AM
xla301
Feb 24, 2005 11:51 AM
Elmojo
Aug 11, 2004 11:13 AM
coolgold02
Sep 29, 2002 11:35 PM
