Catalytic Converter
Old Jul 23, 2002 | 09:46 PM
EF_LSVtec's Avatar
Default Catalytic Converter
Some of you know that I failed my smog inspection earlier today...Anyway, my next step is to get a new catalytic converter. Should I get a stock Cat for a 88 Civic DX (year and model of my car) or a stock Cat for a 97 LS Integra (year and type of my motor)? I'm assuming that the length of both Cat's are the same, I could be wrong, but should I be using a cat made for my type of engine now that I did a swap?
Old Jul 23, 2002 | 09:47 PM
89 CRX SI's Avatar
Default Re: Catalytic Converter (EF_LSVtec)
prolly the engine cause the LS engine breaths more right then your old POS..... or get a catco universal 2.25" one best money spent there
Old Jul 23, 2002 | 09:49 PM
EF_LSVtec's Avatar
Default Re: Catalytic Converter (89 CRX SI)
does the catco universal works as good if not better than stock? if so, how much do they run?
Old Jul 23, 2002 | 09:50 PM
gutted spec's Avatar
New User
If you have the jdm 4-1, then you can't really get either of those without cutting the heck out of it, can you?
Quik89Si's Avatar
I think I read in SCC that Landspeed racing makes Powercore cats (headers also) but they will make the cats in custom lengths. You just send them the specs and they'll hook it up for you. Don't know about cost, I haven't looked into it myself...but hey, it's worth a try.
www.landspeedracing.com
Alex
Old Jul 23, 2002 | 10:40 PM
EF_LSVtec's Avatar
Default Re: Catalytic Converter (Quik89Si)
I will take the jdm header out and replace it with a usdm type r (cast) 2 piece exhaust manifold that I have sitting in my garage. It has the same bolt pattern and length as all stock b-series exhaust manifolds. Only difference I think is the high flow chambers and slightly larger diameter...I bought it from someone who replaced it with a DC header and claims that he didnt gain any power in doing so...I'm sure it'll bolt up to any stock spec cat.
soninihon
Apr 29, 2015 11:17 AM
niteridaV2
Aug 24, 2011 01:28 PM
SpeedRacerEX-R
Sep 14, 2009 07:21 PM
Creator
10
Sep 22, 2007 08:04 AM
IntEGNYC
Jun 20, 2003 08:26 AM
