Full throttle shift on s300
Old Aug 25, 2008 | 10:49 AM
obnoxiousls's Avatar
Default Full throttle shift on s300
I can't get my full throttle shift to work properly on my s300. How do I set that? I cant set it to always on cause then it over rides my rev limiter and it only revs to where I have the full throttle shift set to....???
Old Aug 25, 2008 | 12:28 PM
Gs-RR's Avatar
Default Re: Full throttle shift on s300 (obnoxiousls)
I'm no expert using hondata and I just recently got mine, but I got mine to work.
What I did was use the factory clutch swich from my 95 gsr as the sensor. My car had 2 sensors and I used the one closer to the fire wall, this one will activate when the clutch is in. My car has an alarm so it wasn't usiing it to start the car.
Conect one side of the switch directly to ground and the other terminal to one of the ecu inputs hondata give you to choose from. After this is done, select the input on the preogram and set your rpm. I also used this to activate the lunch control.
Hope this works for you, Enjoy!!
Old Aug 30, 2008 | 07:44 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Full throttle shift on s300 (Gs-RR)
yep thats how
strain gauge input. read about it in the hondata help topic
Modified by HybridcivicLS-T at 11:22 PM 8/30/2008
Fresno_NSX
Apr 25, 2005 04:15 PM
Fresno_NSX
Apr 24, 2005 05:30 PM
lke2drvgsr
Dec 29, 2003 05:49 PM
B18PoweredCivic
Apr 2, 2003 03:15 PM
