95 Civic OEM Style Fog Light Question
Old Aug 25, 2008 | 09:45 AM
BULL3TPR00F's Avatar
Default 95 Civic OEM Style Fog Light Question
Hey, I was reading the OEM instructions on how to install the fog lights in my 95 civic, but theres one thing i want to do differently than what the instructions tell you to do.
I want to make my fog lights independent of my headlights (in the instructions the way they tell you to wire it results in you having to have your headlights on for the fogs to turn on and when your high beams are on they turn off). This is a problem for me since my HIDs are my high beams and i want my HIDs and fogs to turn on together (i can chnage my HIDs to low beam but i dont want to)
I want to be able to turn my fogs on and off whenever i want whether my lights are on or not.
Could someone tell me what i should do differently in order to achieve this?
Old Aug 25, 2008 | 10:20 AM
ej--1socal's Avatar
Default Re: 95 Civic OEM Style Fog Light Question (BULL3TPR00F)
WELL MY FOGLIGHT KIT WAS CONNECTED DIRECTLY TO THE BATTERY THEN TO THE LIGHTS THEN A GROUND AND WENT INTIDE TO MY SWITCH AND TO COMPLETE THE CIRCUIT I CONNECTED THEM TO MY CORNERS.... SO THEY TURN ON WITH MY CORNERS AND I CAN TURN ON MY HIGH BEAMS WHILE I GOT MY FOG LIGHTS ON...
Old Aug 25, 2008 | 10:26 AM
Default Re: 95 Civic OEM Style Fog Light Question (ej--1socal)
Thats what i was thinking about doing, wiring them to the corners.
But then i got thinking and though that since the corners flash for the turn signals, would that not make the fog flash too?
Old Aug 25, 2008 | 10:44 AM
ej--1socal's Avatar
NOT AT ALL ITS JUST TO COMPLETE THE CIRCUIT.. THE ONLY THE THING THOUGH U CANT TURN EM ON WITHOUT UR CORNERS ON.. I DONT MIND THOUGH MAKES IT LOOK MAD JDM WHEN I GOT MY CORNERS WITH MY FOGS ... IVE SEEN SUM SKYLINES THAT THEIR FOGS BLINK WIT THEIR CORNERS SO IT JUST DEPENDS ON U..
Old Aug 25, 2008 | 10:52 AM
Yeah i wouldn't mind the fogs and the corners it looks sick.
Alright thanks a lot for your help man
Old Aug 25, 2008 | 11:33 AM
ej--1socal's Avatar
SHURE THING REMEMBER TO USE UR FUSE AND RELAY BETWEEN UR FIRST FOG AND THE BATTERY... BC THE POWER ITS COMING DIRECTLY FROM IT
Old Aug 25, 2008 | 11:49 AM
alright will do
Old Aug 25, 2008 | 11:50 AM
Apotheosis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej--1socal &raquo;</TD></TR><TR><TD CLASS="quote">SHURE THING REMEMBER TO USE UR FUSE AND RELAY BETWEEN UR FIRST FOG AND THE BATTERY... BC THE POWER ITS COMING DIRECTLY FROM IT</TD></TR></TABLE>
OMG CAPS
Old Aug 25, 2008 | 06:32 PM
blackGSRcoupe94's Avatar
when i wired mine up they came on with just the running lights, i didnt need to have the headlights on at all. did you plug the brown plug under the dash in the #2 slot. but then again i have real oem honda fogs and not sue if they would differ in any way.
redline870
45
Oct 12, 2008 01:23 PM
BlUeHoOdCiViC99
Feb 13, 2008 12:12 PM
BB1LOViN
Aug 29, 2007 07:41 PM
hamadiscool
39
Oct 2, 2006 04:58 PM
marc-111
26
Jan 15, 2005 08:55 PM
