wiring issues after dash swap in eg hatch
Old Aug 25, 2008 | 07:25 AM
2mansi's Avatar
Default wiring issues after dash swap in eg hatch
ok guys well it seems that no one can figure this out in the 92-00 civic forum. My friend recently bought a 92 si hatch and swapped the dash out of his 92 cx hatch into the si since the si dash had a crack in it. Everythign worked perfectly fine in the si before the dash swap so we know that it has something to do with wiring. His problem is that when he turns on the headlights the rear passenger brake light stays on. In addition when you use the turn signal to the right the hazzards turn on and when turned tot he left the the indicators blink fast as if a bulb was out. We have checked eveything to make sure that all the plugs are in the correct spots and they are. I was told that maybe a ground is causing this to occur but i think there is only one ground near the steering wheel.
Any help is greatly appreciated.
Old Aug 27, 2008 | 03:20 PM
ImporTProphetZ's Avatar
Default Re: wiring issues after dash swap in eg hatch (2mansi)
Check all your plugs, there are a few that are interchange-able so if you pluged them into eachother that could cause it. A bad ground most likely is not the cause.
Old Aug 29, 2008 | 03:06 PM
2mansi's Avatar
Default Re: wiring issues after dash swap in eg hatch (ImporTProphetZ)
We have checked all the plugs and they seem to be in the right spot. Guess we will check again.
Anybody else have any ideas
BobbyRodriguez
Jan 16, 2011 06:14 PM
Timmyflys
Oct 12, 2006 08:39 PM
d16vteceg
Apr 27, 2006 11:04 AM
jdmjeff
Dec 31, 2004 06:08 PM
kaoss_11
Aug 21, 2004 06:56 PM
