FS: 93' cx hatch (Well built) in louisiana
Contact: Daniel Norred (318)497-3250 call/text I prefer text
Price: 3600.00
Mileage: Cluster swap so I'm unsure but everything was bought/insalled 3k miles ago.
Vin: Will have it tomorrow.
Bad: The cf hood came up and hit the windshield/roof. The windshield will be new but the roof has a few dings and dents.
I was backed into and it cracked the hood and done minor damage to the headlight/corner light. It is nothing major and only scratched the other car.
No ac
Motor/tranny 10/10
Interior 7/10
exterior 6/10
JDM OBD1 SOHC ZC Non Vtec 1.6 (ordered from Hmotorsonline)
NEW OEM HONDA rear main seal
NEW OEM HONDA front oil seal
NEW OEM HONDA valve cover gasket
NEW OEM HONDA timing belt
NEW OEM HONDA water pump
NEW OEM HONDA oil pan gasket
NEW NGK R plugs
Power Enterprise Air Impulse II Air Intake
Megan Racing 4-1 Header
Test Pipe with 2 1/4 exhaust
Pherable.net chipped Po6 with ZC base map (6800 shift light, 7500 rev limit, o2 sensor delete)
half *** wire tuck
B Series OEM HONDA Oil Cooler
Transmission:
USDM S40 Si/Ex trans 5spd (75k no grinds)
All less than 3000 miles since installed!
NEW OEM HONDA Axel seals
NEW OEM HONDA release bearing
NEW OEM HONDA pilot bearing
COMP Clutch Stage 1
Lightened OEM flywheel
Suspension: All less than 3000 miles since installed!
Skunk 2 sport shocks
Skunk 2 coilovers (550F 440R)
Omni Power rear LCA's with PROTHANE bushings
Billet Strut Mounts/Top Hats with hardened bushings
Brakes: All less than 3000 miles since installed
JDM SIR II front hubs/knuckles
Project MU SCR rotors
Integra Calipers
Satisfied Gransport 5 autox/track pads
Integra Brake Lines
NEW OEM HONDA NISSIN EX master cylinder
NEW rear brake shoes
Exterior:
Type R style front lip
Spoon Style Duckbill wing
Spoon Style Mirrors
Amber corner lamps
Carbon Hood with pins
Interior:
Stock eg drivers and passenger seat
EX cluster
Carpet
No rear seat
Si rear speaker covers
CD player
Wheels/Tires: Less than 700 miles on wheels and tires!
15X7 +33 5Zigen Firezigen wheels
205/50/15 Falken Azenis
^^^The corner that was backed into.
Price: 3600.00
No ac
Motor/tranny 10/10
Interior 7/10
exterior 6/10
NEW NGK R plugs
half *** wire tuck
Transmission:
COMP Clutch Stage 1
Integra Calipers
Integra Brake Lines
Exterior:
Spoon Style Mirrors
Amber corner lamps
Interior:
EX cluster
Carpet
No rear seat
CD player
92integraVTECgsr
May 18, 2016 01:37 PM
JDM_FRONTIN
Apr 11, 2006 09:44 PM
