d16a1 and zc cams
i got a a1 in my civic and a zc that needs the bottom end. would it be hard to put the zc cams in the a1? the zc cams have jg camgears on them would that help any?
yes, you can use the ZC cams in the A1 - not hard to do, just make sure you have engine at TDC - if the JG cam gears are for a DOHC ZC, they won't work in the A1 - the ZC uses cam gears with 34 teeth - the A1 gears have 40 teeth
