oilpan leakageeee
Old Aug 24, 2008 | 07:39 PM
wowy978's Avatar
Default oilpan leakageeee
i got this minor leakage in my oilpan...any suggeston on how to fix it and wat kind of sealant should i use??
Old Aug 24, 2008 | 07:48 PM
kronikSLOW's Avatar
Default Re: oilpan leakageeee (wowy978)
dont use sealant.just drop the pan and put a new gasket takes 45 minutes to 1 hour.if you use sealant the leak will pop back up eventually.but for any sealant on anything else use hondabond.
Old Aug 24, 2008 | 09:15 PM
JDMkid98ls's Avatar
Default Re: oilpan leakageeee (kronikSLOW)
Just replace the thing.
Well be easy and last longer
and you can have the joy of saying you have a brand new oil pan
Old Aug 24, 2008 | 09:21 PM
ruffrhyder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kronikSLOW &raquo;</TD></TR><TR><TD CLASS="quote">dont use sealant.just drop the pan and put a new gasket takes 45 minutes to 1 hour.if you use sealant the leak will pop back up eventually.but for any sealant on anything else use hondabond.</TD></TR></TABLE>
Wat?
Just use permatex ultra grey, it works just as good as hondabond for 1/3 the price.
Old Aug 24, 2008 | 09:24 PM
CompanyFlow's Avatar
Where is it leaking from? Around the pan or from the drain plug?
Old Aug 24, 2008 | 09:40 PM
wowy978's Avatar
Default Re: oilpan leakageeee (CompanyFlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompanyFlow &raquo;</TD></TR><TR><TD CLASS="quote">Where is it leaking from? Around the pan or from the drain plug?</TD></TR></TABLE>not so sure off where its comming from ....but i noeee its around the panna nd not from the drain plug
Old Aug 24, 2008 | 09:45 PM
SLEEPER775's Avatar
get a new gasket and save yourself the headache. dont cut corners.
Old Aug 24, 2008 | 09:50 PM
mr.beeks's Avatar
Default Re: oilpan leakageeee (SLEEPER775)
make sure you follow the correct torque sequense....
Old Aug 24, 2008 | 10:00 PM
If you want to fix it the right way, get a new gasket. If you want a "temporary" fix, use a crapload of silicon.
Old Aug 28, 2008 | 11:46 AM
kronikSLOW's Avatar
if i remember right the oil pan bolts get torqued to 8ftlbs
kaychi
14
Sep 19, 2008 11:37 AM
oem_certified_accord
Jul 19, 2007 04:52 AM
jadugartir
Dec 30, 2005 02:09 PM
stumpyf4
May 21, 2004 01:43 PM
ceemarun
Jun 28, 2002 11:08 AM
