Thought you guys could appreciate this...
Old Aug 24, 2008 | 07:10 PM
Booz's Avatar
Default Thought you guys could appreciate this...
Tech first... anyone have any pointers on changing the suspension in an 89 crx?
You could say between myself and my girlfriend's family we own a lot of semi-rare hondas...
Left to right it's my gf's prelude, her brother's crx, my del sol, my crx, her dad's del sol
Old Aug 24, 2008 | 07:21 PM
thorclark's Avatar
where u find her? Ill i hear is u put so much in that car and its never finished.
Old Aug 24, 2008 | 07:22 PM
Booz's Avatar
Default Re: (thorclark)
Haha, I get that too. But then again I only have to spend about half as much on hers and it keeps her quiet.
Old Aug 24, 2008 | 07:25 PM
2slow4stock's Avatar
Nicee!! Be sure to have the pb plaster handy also be careful of the bolt that holds the rear strut/shock to the lower control arm since i've had the bolt snap right in the middle of taking it out..
The front suspension is easy to replace, the rear just a wee bit tricky if it is the stock 19 year old bolt and shock/strut.
Old Aug 24, 2008 | 08:12 PM
beana's Avatar
Default Re: Thought you guys could appreciate this... (Booz)
love the sol my buddy has a 93 samba green si w/ a bad a$$ built b16a that screams to 10,200rpm (rev limited) damn near sounds like a formula one car
bad part is i get better gas milage in my truck
Old Aug 25, 2008 | 06:41 AM
Booz's Avatar
Default Re: Thought you guys could appreciate this... (beana)
Well I bought the white del sol becuase it had 70k original miles on it and I drive 600 miles a week. I didn't realize that I'd get such shitty gas mileage considering the red one gets 40mpg as a s model but mine only gets absolute max with all highway 30mpg.
Old Aug 25, 2008 | 07:07 AM
MyHotsh's Avatar
Good luck with the suspension. 9 out 10 times the rear bolts on the struts are siezed in the bushings , if its original suspension.
The front is easy so do it last.
Very nice cars...
Old Aug 25, 2008 | 07:27 AM
crxhondata's Avatar
nice color what can blue is that
Old Aug 25, 2008 | 07:34 AM
Booz's Avatar
Default Re: Thought you guys could appreciate this... (crxhondata)
Which crx?
Old Aug 25, 2008 | 11:47 AM
crxhondata's Avatar
the blue one
Old Aug 25, 2008 | 11:59 AM
Booz's Avatar
Well, from the pictures I see what you mean. His is actually blue too, a maaco blue whatever color that is. My car was already this color and the closest I've been able to match to it is electron blue but it's a bit off.
Old Aug 25, 2008 | 03:34 PM
dlaub25's Avatar
Well I just happened to have replaced the suspension (front and rear) on my 89 CRX Si. It was all original when I took it off. I didn't run into any problems as far as things being seized, the one problem I did have was the mounting bolts and tapped holes for the rear upper control arms. Their threads had been squashed and it was impossible to get them started. So out came the tap set (i think thats what others call it?) and 15 minutes later I was back on track.
BTW If your looking into what setup to get, I installed Koni Sport yellows and Ground Control coilovers with front rates of 440 and rear rates of 350. I couldn't be happier. I think they were one of the best investments I have made.
Old Aug 25, 2008 | 04:28 PM
detuned's Avatar
My 89 HF's bushings (bolts on the strut?) had seized. Ending up having to use pliers, which then fried the struts.. I'd say grab new struts.
Old Aug 25, 2008 | 06:45 PM
crxhondata's Avatar
looks clean i decide to paid my that color look like si blue to me
Old Aug 25, 2008 | 08:03 PM
Booz's Avatar
Default Re: Thought you guys could appreciate this... (dlaub25)
I'm going to be running something similar, Koni yellows all the way around but gonna use eibach springs 400 front, 325 rear and the sleeves from a previous suspension setup if I have to.
Old Aug 25, 2008 | 10:49 PM
harmonator84's Avatar
Actually I never had any problems removing suspension. Just make sure you have the right tools and be patient getting the bolts out.
Pics of the girlfriend!!!
Old Aug 26, 2008 | 05:14 AM
dlaub25's Avatar
Yeah thats basicly the same setup. Ground control uses Eibach springs on their coilovers. If I could change one thing I actually would have went a little stiffer on the springs. But I guess I have a somewhat high tolerance for a rougher ride. My girlfriend does not complain about the comfort of the ride with the current rates though. .
Old Aug 26, 2008 | 06:21 AM
Booz's Avatar
Default Re: Thought you guys could appreciate this... (harmonator84)
I'll try to get a pic of her on here just for you guys, I'll have to run it by her first or she'll kick my *** for not asking
Old Aug 26, 2008 | 04:43 PM
slicedbreadno2's Avatar
Nice collection of cars.
Old Aug 28, 2008 | 08:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Booz &raquo;</TD></TR><TR><TD CLASS="quote">I'll try to get a pic of her on here just for you guys, I'll have to run it by her first or she'll kick my *** for not asking </TD></TR></TABLE>
Wuss
Joseph Michaud
14
Feb 13, 2017 11:03 AM
jsucci
Jan 4, 2008 05:48 PM
1PT-SICK
May 18, 2007 10:23 PM
cpizzy
Dec 20, 2003 08:02 PM
