rockford fosgate p300.1
ive got a rockford fosgate p 300.1 amp that i had wired to 2 p1 fosgate subs but the voice coils blew on them so i was thinkin about hooking the amp up to some 6x9s and some 5 1/2s in the door would that amp be big enough to put some good coaxial speakers all the way around and if so what kind would match good with it?
No, it will not work, it is a mono block, [one channel] amp, although you could use it for the rear speakers you will need a stereo, [two channel] amp for the fronts.
94
94
