passenger rear lower control arm from 90 ef the same as passenger rear lower control arm from 90 int
is it the same? the bolt when doing my suspension seized and i need replace the bushing, but my ef is going ot the scrapper so i have a rear lca thats on there will it fit? please answer asap
Pretty sure it'll fit, seeing that they are the same part numbers for DA's and EF's in aftermarket LCAs. Try taking the one off your EF and matching it up!!
If there's a difference, it'll probably be that the EF might not have a spot for the rear swaybar to mount to..
lol i know that , but thats what i didnt wanna do, pulling that one off and finding out it doesnt fit, thanks tho
and its an si so it should have the bolt hole for the rear sway bar
