Please help ignition question
Old Aug 24, 2008 | 02:29 PM
r1lorenzini's Avatar
Default Please help ignition question
My 92 stock si will sometime not start when it is hot outside. All other time it works fine. I have boought a new distributor including coil and module and this did not solve my problem. The car will sometimes try and start but then it is like it is losing spark or fuel. it always cranks over so it is not the starter. please help Joe in nor cal.
Old Aug 24, 2008 | 04:58 PM
Default Re: Please help ignition question (r1lorenzini)
ttt
Old Aug 24, 2008 | 06:39 PM
cjo_28's Avatar
The first thing to check is your main relay. Extremely common problem for your vehicle. If you do a search, someone might have explained how to repair the faulty solder joint. Or you can just buy a new one. You probably can pick one up online for $40 or so.
Old Aug 24, 2008 | 07:23 PM
Default Re: Please help ignition question (cjo_28)
oh man thanks alot that is great news!!!!
CRX 2.0V-T
Dec 9, 2007 06:56 PM
whojoedaddy
Feb 15, 2005 06:40 PM
94_CRVtec
Jan 6, 2005 11:48 AM
ricodemus
Mar 4, 2003 03:18 AM
HailRedskins
Aug 28, 2002 10:56 AM
