Changing EF fuel filter
Old Aug 24, 2008 | 01:42 PM
91CiviHatch's Avatar
Default Changing EF fuel filter
I know the fuel filter is located on the firewall and i just had a few questions about replacing it.
Is it a pressurized system when the car is off? And is it more complicated than unbolting the old one and putting the new one up and re-attaching the hoses, or am i overthinking it?
Old Aug 24, 2008 | 01:49 PM
Booz's Avatar
Default Re: Changing EF fuel filter (91CiviHatch)
When I changed the one in my 89 crx I simply took the gas cap off to relieve pressure, then removed the lines to it, ubolt the bracket holding it in place, bolt up the new fuel filter, attach the lines.
Also, to make sure there aren't any leaks turn your key to the last click before it starts the car so fuel starts flowing and check the filter out to see if it's leaking anywhere.
Old Aug 24, 2008 | 01:52 PM
reznunt's Avatar
here's how i did it:
1. open the fuel cap.
2. loosen the service bolt to de-pressurize line.
3. unbolt old filter and replace with new one torquing all bolts to spec.
use new washers... your fuel filter should come with them.
Old Aug 24, 2008 | 01:55 PM
IntegraLova's Avatar
Im pretty sure the system isnt under pressure after you take the fuel cap off. Thats all i did on my dc before changing the filter. There will be some fuel left in the lines but should just drain out rather than spray out.Its a pretty straight forward procedure.Main thing is just be prepared to catch/ soak up the gas that will run out.
Old Nov 8, 2008 | 04:25 PM
hatcht9x's Avatar
Default Re: Changing EF fuel filter (IntegraLova)
when replacing the washers.. can you use any copper/ aluminum washers that will fit?
I was reading that the copper ones are better.. and that they are supposed to be 'crush washers'.. can you find these at any hardware store?
thanks guys
Old Nov 8, 2008 | 06:21 PM
sgallagher's Avatar
Default Re: Changing EF fuel filter (hatcht9x)
"Crush" washers is just a term for a washer used to seal a fluid using a bolt, etc..
They "crush" because it is a soft metal(brass or alum.).
They should come with a new filter. I have never seen them not come with it. Even from Honda.
Old Nov 8, 2008 | 08:00 PM
hatcht9x's Avatar
Default Re: Changing EF fuel filter (sgallagher)
well i wasnt replacing the filter.. i needed to disconnec the fuel line to drop my motor.. now, putting it back together it leaks..
Old Nov 9, 2008 | 08:51 AM
acmoc's Avatar
Default Re: Changing EF fuel filter (reznunt)
this is the rite way
the service bolt is the weird shaped one
Old Nov 9, 2008 | 09:07 AM
hatcht9x's Avatar
Default Re: Changing EF fuel filter (acmoc)
thanks for the info..
thanks for the response.. so I could get these at the hardware store then..
thanks guys!
Old Nov 9, 2008 | 12:21 PM
90sedan's Avatar
thanks guys!
Yes, just get the same size.
Old Nov 9, 2008 | 12:41 PM
hatcht9x's Avatar
Default Re: Changing EF fuel filter (90sedan)
cool.. thanks man
Old Nov 10, 2008 | 02:41 PM
traxxasx's Avatar
If u buy a filter from autozone they come with new crush wahsers, one goes on bottom an one on top.
GabeBellaflores
Dec 4, 2018 09:29 PM
magic hat #9
Jan 9, 2009 07:23 AM
STLblackcivic
Mar 26, 2007 03:12 PM
TMC_EF
Mar 22, 2007 01:07 PM
CivilizedCiv
Aug 22, 2002 08:22 AM
