FS: 1991 Honda CRX Si. NO RUST! SUPER CLEAN!!!! Turbo B16a, Full Race, Hondata, RC, Hasport+MORE. NY
SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD
Here is all the info. I will try to be as thorough as possible and hopefully I can include everything.
I bought the car from a guy in Tennessee and had it shipped to me in New York. He was the original owner and kept the car 100% stock and mint. The only owners have been him and me. There is no rust on the car. It spent most of its life in the south so you can imagine how clean it is. I garaged it during the winters too. The car is in great shape. Clean title. No accidents. I put every mod on this car and spared no expense as you will see.
Here is the modification list. I am sure I am missing somethings as the car has so much into it.
1991 CRX Si Modifications
<U>Interior</U>
Momo Competition Steering wheel
NRG Quick Release Steering Hub with Lock
Autometer Shift Light
Boost Gauge (in glove box)
Shift ****
E-Brake Handle
Floor Mats
CD Player
OEM Rear speaker brackets with speakers
Full Complete Interior
<U>Exterior</U>
OEM JDM SIR Wing
OEM JDM SIR Wiper arm and motor 100% works with spoiler
OEM JDM SIR VTEC Taillights
OEM JDM SIR Rear Badge
OEM JDM SIR DOHC VTEC Door Decal
VIS JDM SIR CF Hood
Hood Pins
J’s Racing Replica Front Lip
Amber Corner and Bumper Lights
License Plate Relocated to the side
OEM USDM Rear Mud flaps
<U>Handling/Suspension</U>
Omni Power Suspension
15x6.5 Black Rota Slipstreams
Muteki Lug nuts
JK Motorsports Traction Bar
Brembo Blank Rotors
<U>Engine</U>
B16a
ARP Headstuds
GSR cams
Skunk 2 Intake Manifold
62mm Throttle body
AEM Fuel Rail
AEM Fuel Pressure Regulator
Marshall Liquid Filled Fuel Pressure Gauge
S1 Transmission
Hasport Engine Mounts
C&R 1/2 Size Dual Core Radiator
Optima Red Top Battery
Battery Relocated to Hatch
KMS Fab Catch Can
Z10 Rear Plug
Valve Cover Breather
<U>Turbo Setup</U>
Full Race Ramhorn manifold
Full Race Backdoor Intercooler
Full Race Charge Pipes
Full Race Oil Lines
Full Race 3" Down Pipe
Tial 50mm BOV
Tial 44mm Wastegate
Garret T3/T04E 57trim .63 A/R turbo
Custom 3" Test pipe
Thermal 3" exhaust
Fast Turbo Vacuum Bar
<U>Electronics</U>
OBD0 - OBD1 Conversion
P06 ECU with Hondata S300
Walbro 255lph HP Fuel Pump
RC750cc Injectors
TD-44u Distributor
NGK Blue Spark Plug Wires
GM 3 Bar Map Sensor
<U>Extras:</U>
On top of all the mods I have bins of extra parts. I have extra interior pieces, stock injectors, stock headstuds, different spring rates for the coilovers, alternators and more. Ill give you everything CRX related I have.
<U>Other</U>
Tuned by NRG TECH
The car made:
325 whp
219 ft-lb torque
<U>Here are the only downsides. It does need a clutch as this one slips and can't hold the power. An alignment would also be recomended. The sunroof does not work. It always worked since I first got the car then stopped one day. It should just be the sunroof relay which is fairly cheap. Also just recently the fuel pump has been priming intermittently. It is most likely just a loose wire on the walbro fuel pump. It's an easy fix but right now I do not have the time. Other then that this car is mint and is well worth the asking price.</U>
Here are pics exactly how you would get the car if you bought it.
<U>Exterior Shots:</U>
Carbon Fiber Hood
NO RUST ON THE QUARTER PANELS
<U>Interior Shots:</U>
Full Interior
Drivers seat NOT ripped
Battery Relocated to the hatch
<U>Engine Bay Shots:</U>
Modified by TurboEM1 at 8:22 PM 9/1/2008
<U>Interior</U>
Shift ****
E-Brake Handle
Floor Mats
CD Player
<U>Exterior</U>
OEM JDM SIR Wing
VIS JDM SIR CF Hood
Hood Pins
Muteki Lug nuts
Brembo Blank Rotors
<U>Engine</U>
B16a
ARP Headstuds
GSR cams
62mm Throttle body
AEM Fuel Rail
S1 Transmission
KMS Fab Catch Can
Z10 Rear Plug
<U>Turbo Setup</U>
Full Race Oil Lines
Tial 50mm BOV
Tial 44mm Wastegate
Custom 3" Test pipe
Thermal 3" exhaust
<U>Electronics</U>
RC750cc Injectors
TD-44u Distributor
GM 3 Bar Map Sensor
<U>Extras:</U>
<U>Other</U>
Tuned by NRG TECH
The car made:
325 whp
219 ft-lb torque
Carbon Fiber Hood
Full Interior
FS: 1991 Honda CRX Si. NO RUST! SUPER CLEAN!!!!!!!! Turbo B16a, Full Race, Hondata, RC, Walbro, Hasp
TurboEM1
Sep 1, 2008 04:23 PM
1badascivic
Mid-Atlantic (Sales)
Mar 9, 2008 11:20 AM
