How many teeth on timing belt between TDC arrows on cam gears?
Old Aug 24, 2008 | 11:58 AM
slammin86's Avatar
Default How many teeth on timing belt between TDC arrows on cam gears?
I just put a new timing belt on my car, but it seems pretty loose on the top. How many teeth are supposed to be on the belt between the two top arrows?
I counted 14 on mine, but it is really loose.
Old Aug 24, 2008 | 12:10 PM
snobordboy's Avatar
Moderator
Did you follow the tensioning procedure properly? Are the cam gears and crank gear set at tdc properly? auto or manual tensioner? These are things we need to know.
Old Aug 24, 2008 | 12:16 PM
slammin86's Avatar
Default Re: (snobordboi)
Here are some pictures.
Old Aug 24, 2008 | 12:17 PM
slammin86's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snobordboi &raquo;</TD></TR><TR><TD CLASS="quote">Did you follow the tensioning procedure properly? Are the cam gears and crank gear set at tdc properly? auto or manual tensioner? These are things we need to know.</TD></TR></TABLE>
It is a 97 prelude w/ H22. Everything is set properly at TDC. And after 8 revolutions everything still lines up. I stayed with the auto tensioner. Currently the auto tensioner still has the holder on it...I have not taken it off to put tension on the belt yet.
Old Aug 24, 2008 | 01:28 PM
Giant_Bean's Avatar
Default Re: (slammin86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammin86 &raquo;</TD></TR><TR><TD CLASS="quote">
Currently the auto tensioner still has the holder on it...I have not taken it off to put tension on the belt yet. </TD></TR></TABLE>
that would be why, put tension on the belt, rotate a few times, and double check to make sure you are still where you are supposed to be.
Old Aug 24, 2008 | 02:04 PM
Hawkze_2.3's Avatar
Default Re: How many teeth on timing belt between TDC arrows on cam gears? (slammin86)
You are definitely off at least one tooth at the top.
Old Aug 24, 2008 | 02:26 PM
slammin86's Avatar
Default Re: (Giant_Bean)
It is a 97 prelude w/ H22. Everything is set properly at TDC. And after 8 revolutions everything still lines up. I stayed with the auto tensioner. Currently the auto tensioner still has the holder on it...I have not taken it off to put tension on the belt yet. </TD></TR></TABLE>
I figured it out. I still had the bracket in the auto tensioner holding it while those pics were taken. I took out the bracket and rotated the engine a few times and everything tightened up.
You were right.
Old Sep 24, 2008 | 04:28 PM
adam00's Avatar
on my friends h23 and jdm f22b there was 13 teeth in between
IntegraTionR
Jul 19, 2020 04:57 PM
scoob8000
Dec 19, 2011 11:57 AM
Dased530
Aug 7, 2005 04:52 PM
redlseg
Apr 20, 2005 07:07 PM
