Suspension & Brakes Theory, alignment, spring rates....
how to maintain trailing arm spherical bearing kit?
Old Aug 24, 2008 | 09:30 AM
onereving7's Avatar
Default how to maintain trailing arm spherical bearing kit?
What can i use to clean the rear bearing and keep it lubed? I dont daily drive the car, but i do use it on the street and the other night i ran into some nasty rain. The rear bearing is a little dirty. Can i use silicone spray or anything?
Old Aug 25, 2008 | 06:04 PM
.:Made in OC:.'s Avatar
Default Re: how to maintain trailing arm spherical bearing kit? (onereving7)
What kind of spherical RTA bushing are you running?
Old Aug 25, 2008 | 06:24 PM
dfoxengr's Avatar
Default Re: how to maintain trailing arm spherical bearing kit? (.:Made in OC:.)
most normally take a teflon lube. and wd-40 will attract dirt.
Old Aug 25, 2008 | 06:35 PM
slammed_93_hatch's Avatar
Default Re: how to maintain trailing arm spherical bearing kit? (dfoxengr)
i think the new stuff is self lubricating not 100 percent sure though.
Old Aug 25, 2008 | 09:51 PM
japanjay's Avatar
* B A N N E D *
This might help, not sure though. In the desert when we deploy, equpiment like our forklifts use graphite on the bar that the forks slide wider and closer on. In the states we just use axle grease, but since it is so dusty here the graphite works better and the dust does not stick to it. I am not sure about it waterproof capabilities though. Might work for those bearings. Just an idea.
Old Aug 26, 2008 | 09:34 AM
onereving7's Avatar
Im running the password kit. I will need to find something at least to clean around them, im thinking a light coat of silicone spray
Old Aug 26, 2008 | 10:20 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (onereving7)
too bad all spherical RTA bushings on the market don't have rubber boots like HardRace's version does.
Old Aug 27, 2008 | 09:37 AM
onereving7's Avatar
yea, i thought about trying to make something, or looking for some universal boots online, its sad for the price of them that they dont include them
Old Aug 27, 2008 | 10:17 AM
MSchu's Avatar
My Name is Nobody
WD40 is a solvent not a lubricant...
Old Aug 30, 2008 | 08:29 PM
Jaker's Avatar
Default Re: how to maintain trailing arm spherical bearing kit? (MSchu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">WD40 is a solvent not a lubricant... </TD></TR></TABLE>
WD40 is actually a Water Displacement (40th formula) product developped for rockets in the 50s.
Old Oct 31, 2008 | 11:34 AM
Kuppa's Avatar
Default Re: how to maintain trailing arm spherical bearing kit? (Jaker)
i was just about to say that tri flow might be ok to use i believe its teflon
kamranm3
Jun 20, 2011 06:27 AM
949
May 24, 2008 06:08 PM
Hahnduh
Nov 10, 2007 01:15 PM
