86CRX-si i need a good base motor i wana go all out TURBO i have 15k to spend right now on it
Old Jul 23, 2002 | 08:07 PM
CRX-TurboMan2's Avatar
Default 86CRX-si i need a good base motor i wana go all out TURBO i have 15k to spend right now on it
ok this is whats up i just got my first import this 86 CRX i wana spend 15k on it right now then later mabee more!! i been told many times just to swap the old 1 out... should i or should i not???? and see what i can get out of it with the 1.5 pg fi 12v ?? and if i sawp what should i go with?? still be able to keep putting mony in to it at mind. i don't really know to much bout imports. but my goal is to have my CRX keep up with my 63 nova 350 on juice 250shot . and i know i can do it. by the way it's pulling mid. to high ten's .........O and i would be doing all the work so no labor bill wich means better **** so hook me up peps cuss i have not a cule but i need 1 so hook it up
Old Jul 23, 2002 | 09:42 PM
the DR.'s Avatar
Default Re: 86CRX-si i need a good base motor i wana go all out TURBO i have 15k to spend right now on it (
wow... 15k?!?!?! if i were you i'd start with another car, maybe a 2nd gen crx and go from there, should be alot easier. then go LS turbo if you really want a turbo car. use your 86 rex as a daily driver while your other car is out of comission
Old Jul 23, 2002 | 09:46 PM
89 CRX SI's Avatar
15 K on a import is a lot.... get a 2nd gen for about 2K then a b20 Turbo with Nitrious then add traction and left over for some paint/ bodykit/suspension etc. that is enought to do an entire car in one week 24 -7 id work on it if i had unlimited finds.
Old Jul 23, 2002 | 09:53 PM
EF'n Fast's Avatar
$15k is a lot of money to spend on a 86 crx...
but if you insist...start with motor swap?
[Modified by EF'n Fast, 7:03 AM 7/24/2002]
Old Jul 23, 2002 | 10:44 PM
KS-R's Avatar
$15K? Damn.. I only wish I can count that high.. LOL.. I agree with everyone else.. 2nd gen... But again.. if you insist.. motor swap
Old Jul 23, 2002 | 11:44 PM
EF_LSVtec's Avatar
I second the B20 turbo-nitrous ...But mind you all, 15K will go quick. I spent close to 12K on mine and I'm not even done yet...Just add up 5K for a fully built B20, 4K for the Turbo with all the necessary add ons and not to include, Tranny, clutch, suspension, seats, carbon fiber stuff or fiberglass to lighten the car and roll cage (for a 10sec car)...Good luck and enjoy spending your 15K, we're all with you all the way...
Old Jul 24, 2002 | 01:26 AM
REX VT's Avatar
Stick with the 1st gen if it's in very good condition: For the engine use the B20z block with a type R head and go turbo..
Old Jul 24, 2002 | 05:19 AM
WuShu's Avatar
New User
15k! damn, if your taking opinions, i would get a 2nd gen, get one of those indestructable blocks from darton, sleeve that sucka, bore it out. 2 liter, then boost that thing with a blitz turbo kit till the cows come home!
waddles08
26
Jul 5, 2005 05:36 PM
