98 integra b18b1 non vtech
Old Aug 24, 2008 | 08:55 AM
vinceg143's Avatar
Default 98 integra b18b1 non vtech
has 160 000 k should i bother with trying to make it fast or save my money and buy a diffrent engine or diffrent car all together. its a dd
Old Aug 24, 2008 | 09:06 AM
p1k's Avatar
p1k
Default Re: 98 integra b18b1 non vtech (vinceg143)
Your going to get some very opinion based answers, i think you should think to yourself if YOU think it's worth it and act on that. Whos to say that your 160000k motor won't last longer than for instance my 140000 mod'd motor.
But basically any MAJOR upgrade (Turbo/lsvtec) that you can do to your motor would include freshening up the internals (valve job/pistons, etc.) So why not?
Old Aug 24, 2008 | 09:21 AM
vinceg143's Avatar
Default Re: 98 integra b18b1 non vtech (p1k)
i always see lsvtech does same thing go for rs or gs
Old Aug 24, 2008 | 10:03 AM
JDMkid98ls's Avatar
You should maybe begin with reboring your valves and upgrading the piston size first.
Some integras begin to burn oil at the valves due to use after they hit about 150k or so.
Just a heads up.
Also larger pistons will give you a little extra power
Old Aug 24, 2008 | 10:39 AM
be18see1's Avatar
i think hes at 160k kilometers. thus, the mileage isnt too bad. id pull that motor and put in .25 oversized itr or ctr pistons and then get a vtec head. good luck!
Old Aug 24, 2008 | 11:08 AM
VTECisSeXY's Avatar
*insert here*
bah just boost her for $2k and walk all over that ls vtec
Old Aug 24, 2008 | 11:18 PM
Adambomb's Avatar
Default Re: (VTECisSeXY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECisSeXY &raquo;</TD></TR><TR><TD CLASS="quote">bah just boost her for $2k and walk all over that ls vtec </TD></TR></TABLE>
He'd have to do a compression test first to see if it's still healthy, even though it only has 100k miles, still getting up there. I agree though, if the engine's still solid, just boost it.
phirewire
Jun 28, 2011 12:28 PM
bigsnorlax
Mar 22, 2011 08:27 PM
Sir Kyle
Mar 7, 2008 08:39 PM
^jefs0ng
Dec 9, 2003 06:48 PM
96SR-V
Mar 22, 2003 06:48 AM
