before you swap an h22 you should... ?
Old Aug 24, 2008 | 02:18 AM
Enigmatic92's Avatar
Default before you swap an h22 you should... ?
Hi, I'm having an h22 put into my 92 accord in a couple weeks and I've done some searching for what little upgrades I could do while I have the motor out besides routine maintenance stuff like timing belts, seals etc. It was suggested to me that I buy an alluminum clutch master flywheel for 150 bucks and get a stage 2 clutch installed.. these suggestions came from the guy that's installing it and I don't wanna get ripped off. I'm not going "all out" but I'm wondering what relatively cheap mods I could do while it's easy and not labor intensive. With a budget of 6-800 bucks.. what would you do with it?
I have a feeling theres a website out there answering this but I haven't found it : /
Thanks
Old Aug 24, 2008 | 11:53 PM
Default Re: before you swap an h22 you should... ? (Enigmatic92)
64 ppl have viewed this and no one has given an opinon =O I'm astonished
Old Aug 25, 2008 | 05:30 AM
TOAB's Avatar
I'd highly recommend driving a car with a light aluminum flywheel before just going out and buying one. Going too light can cause anything from annoying driving, to killing your hole shot.
Old Aug 25, 2008 | 07:07 AM
TheMuffinMan's Avatar
He knows where you live!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enigmatic92 &raquo;</TD></TR><TR><TD CLASS="quote">64 ppl have viewed this and no one has given an opinon =O I'm astonished
You should read the FAQ's about the swap........
Old Aug 25, 2008 | 08:52 AM
Conflicted's Avatar
There's lots of information in the FAQ's and there are lots of things you're going to need from some new OEM parts to even some aftermarket parts which will be easier to change right now instead of later.
Old Aug 25, 2008 | 11:12 AM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enigmatic92 &raquo;</TD></TR><TR><TD CLASS="quote">Hi, I'm having an h22 put into my 92 accord in a couple weeks and I've done some searching for what little upgrades I could do while I have the motor out besides routine maintenance stuff like timing belts, seals etc. It was suggested to me that I buy an alluminum clutch master flywheel for 150 bucks and get a stage 2 clutch installed.. these suggestions came from the guy that's installing it and I don't wanna get ripped off. I'm not going "all out" but I'm wondering what relatively cheap mods I could do while it's easy and not labor intensive. With a budget of 6-800 bucks.. what would you do with it?
Thanks
i have an ACT prolite flywheel and heavy duty ACT pressure plate and 6 puck clutch disc for sale if you are interested? $300 for all of it.. pm me if ur interested.
Trey Brown
Jul 1, 2011 07:00 AM
Haccordclub
Jul 31, 2007 07:41 PM
tougeEGsies
Feb 11, 2005 10:06 PM
Boosthead
May 6, 2003 04:57 AM
Train
Apr 9, 2003 09:01 PM
