FS: 96' HATCHBACK *EK SQUAD*
FOR SALE:
1996 honda civic hatchback dx
color - black
chassis miles - 90k
motor - 1000+ miles(freshly built)
title - clean
price - $6500 FIRM
vin - Serious buyers only, NO JOY RIDES, CASH TALKS!!!!
Many people can vouch for this car,...pm for more info!
I just got this car fully tuned on a dyno as of 9/26/08 by rich at pinamotor sports. hit 197hp, 157trq on a dyno dynamic dyno, which reads 17% lower than a dyno jet.
<u>pro's</u>: I've had this car for 4year its only driven 2-3times a week. well maintained garaged at all times. Clean interior. Car is Very Fast. New tabs as of 09/25/08, good untill next year for emissions. Motor very healty and strong. tons of mods to the engine. all machine work was done at highlines east machine shop. Decked,hot tanked,bead blasted, bored, and honed. Head work - basic valve job, new valves, new valve guides, valve stem, and resurfaced. spent over $600 on machine work.
<u>con's</u>: paint is 8/10 needs a good wetsand and polish/buffing. Trunk only opens manually from the lever from the back of the trunk from the inside because the bolt broke on the latch. Fuel is hook up to a switch so it only runs off that, can be rewired to prime with main relay turns on. Car must warm up at least 5-10mins before it can even move or it'll just keep dieing (timing issue). Has check engine light on for IAT, it's wired up but cant figure out the problem.
Engine:
B20Vtec
-Gsr head
-Omni dual valve springs
-Omni ti retainers
-Mild port and polish
-Skunk2 pro1+ camshafts
-Skunk2 pro-series intake manifold
-Skunk2 tuner cam gears
-Hondata Intake manifold gasket
-Custom 3”Intake piping
-Blox velocity Stack w/ K&N Filter
-BDL 70mm Throttle body port matched
-Aem Fuel rail w/ Fuel pressure gauge
-Rx7 440cc injectors
-Rage 4-2-1 headers Thermal wrapped
-Samco blue radiator hoses
-Aluminum dual core radiator
-Spoon Thermostat
-Spoon Fan switch
-Spoon reservoir covers
-Spoon oil cap
-ARC radiator cap
-Walbro 190lph fuel pump
-Engine torque damper
-JDM ITR valve cover w/ cut cam cover
-Dry Kevlar Spark plug cover
-NGK Blue spark plug wires
-Endyn Chamber Breather kit
-MFactory Catch Can
-Golden Eagle Vtec Conversion Kit
-ARP Head Studs
-Fully Balanced Rotating assembly
-Bored/Honed/Bead Blasted
-Hot tanked/decked
-RS Machine Pistons 84.5mm (12:3:1)
-Ls rods w/ ARP rods bolts
-ACL rod/main/thrust bearings
-Center Force Stage 1 clutch
-Fidanza 7.5lbs Flywheel
-unorthodox racing pulley
-T1R Test Pipe
-T1R 63mm exhausts system
Exterior:
-JDM CTR power folding mirrors
-JDM CTR rear lip
-JDM CTR head Lights w/ city lights
-JDM CTR front lip
-JDM amber city lights
-OEM stock CX spoiler
-OEM 99-00 Si fog lights
-OEM 99-00 Taillights
-OEM Civic Si Grill
-99-00 carbon fiber hood oem style
-Amber Side markers
-window visors
-2.0 badge
-Stupid hurts “Honda”
Interior :
-6point Roll cage
-recaro speed *black* driver seat
-no passenger seat
-Mugen e-brake cover
-ebay steering wheel/hub
-stock ex cluster
-EDM amber clock
-Circuit Hero ti ball shift ****
-Skunk2 short shifter
-CTR red/black shift boot
-CTR red door panels
-Custom Black carpet (TAKATA HARNESS NOT INCLUDED)
Suspension / Brakes :
-h&r lowering springs
-stock ek suspension
-brand new rotors and pads
-brake flush
-alignment done
-GSR fat fives
Modified by SpoonEk253 at 1:14 PM 10/12/2008
Modified by SpoonEk253 at 5:51 PM 10/15/2008
color - black
chassis miles - 90k
title - clean
price - $6500 FIRM
Engine:
B20Vtec
-Gsr head
-Omni ti retainers
-Spoon Thermostat
-Spoon Fan switch
-Spoon oil cap
-ARC radiator cap
-MFactory Catch Can
-ARP Head Studs
-Hot tanked/decked
-T1R Test Pipe
Exterior:
-JDM CTR rear lip
-JDM CTR front lip
-OEM Civic Si Grill
-Amber Side markers
-window visors
-2.0 badge
Interior :
-6point Roll cage
-no passenger seat
-stock ex cluster
-EDM amber clock
-brake flush
-alignment done
-GSR fat fives
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99fbpem1 »</TD></TR><TR><TD CLASS="quote">This car looks amazing. Good luck</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -JSpecEk*9- »</TD></TR><TR><TD CLASS="quote">bump
such a sickk car.
Bump, some lucky guy can own this!
such a sickk car. Bump, some lucky guy can own this!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .joeham »</TD></TR><TR><TD CLASS="quote">
such a sickk car.
Bump, some lucky guy can own this!</TD></TR></TABLE>
such a sickk car. Bump, some lucky guy can own this!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jime64871 »</TD></TR><TR><TD CLASS="quote">You willing to sell the rollers separate? </TD></TR></TABLE>
get back to me in a week....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonEk253 »</TD></TR><TR><TD CLASS="quote">
sure thing..
</TD></TR></TABLE>sure thing..
