clutch grind only when ebrake light stays on
ok I search your forums and found really good advice, but pretty common sense. I have 2 problems that I hope are not 1. i have the clutch grinding problem some other people have when I push in the clutch, leading me to think it's a TO bearing. I also have a parking brake light that sometimes stays on. So I will check the reservior. and fluid levels and brake pads for wear. Here is my problem, they only both happen at the same time. I mean if the parking brake light goes off when I release it there is never and clutch gring. But if the light stays on there is always clutch grind. How can these 2 things be related.....so weird...help me out oh geniuses of honda tech.
BiffStroganoffsky
Jun 2, 2015 07:28 PM
low on fluid or bad wiring if the fluid is full. as far as the light is concerned
