help!
I'm having a little wiring problem.
PIC NOT OF MY CAR
the wire in the pic... first of all my car is a 91 civic dx, and i put a d16a6, but the engine did not come with the wiring harnest, so i found a wiring harnest laying around that came off a sohc zc. the plug coming from the engine has 8 wires, but the one coming for the car has 12, what do i do.
thanks in advance
Modified by josh.p at 7:24 PM 8/23/2008
PIC NOT OF MY CAR
thanks in advance
Did you do the appropriate modifications for the DPFI to MPFI swap? I don't know what's involved, but that may be your issue.
Also, are you sure that you are matching up the correct plugs - not trying to plug one of the connectors from the opposite side of the bay in there?
no i have it going the right way, the resister box is right beside the plug. but all the wiring for the dpfi to mpfi is confusing to me, do you know a good really detailed forum ? i have a si ecu, i have the resister box, i just need to do the conversion
bmanuhutu
Nov 2, 2009 12:26 PM
FourthGenHatch
Sep 2, 2003 04:20 AM
paybac4223
Jan 29, 2003 10:13 AM
