Help: clutch and brake levers scratching fairings when maxed out
Old Aug 23, 2008 | 12:52 PM
98GSRDC2's Avatar
Default Help: clutch and brake levers scratching fairings when maxed out
i have a problem on my new 04 cbr 600rr. the problem is that on my bike, when i turn all the way to the left or the right, the clutch and brake lever scratchs the top of the fairings. so im guessing the handle bars are too low, so is there a way to adjust it??
thanks
Old Aug 23, 2008 | 01:00 PM
rdblckSV650S's Avatar
Default Re: Help: clutch and brake levers scratching fairings when maxed out (98GSRDC2)
Is this with stock parts?
Old Aug 23, 2008 | 01:26 PM
life sux die's Avatar
RIP 1032
stock parts? pics?
Old Aug 23, 2008 | 03:08 PM
spoon063's Avatar
Default Re: Help: clutch and brake levers scratching fairings when maxed out (life sux die)
theres a 5mm allen or 8mm bolt to loosen and angle them up or down, i had point both of mine down
Old Aug 25, 2008 | 07:42 PM
marmaladedad's Avatar
Along with adjusting the angle of the levers, you can adjust the angle of the clip-ons. You would need to loosen the bolts that hold on to the clip-on (typically two allen-type bolts). These are located near the triple tree. Only loosen them enough to rotate the clip-on. Most likely you need to rotate them in (towards the tank) a little bit.
NathanMorris
Apr 10, 2015 12:43 PM
wantboost
Mar 23, 2013 02:15 PM
swappedcx
Welding / Fabrication
Jun 27, 2008 09:04 PM
85
Honda Motorcycles
Jan 6, 2005 07:38 PM
d8168055
Jun 21, 2002 10:16 PM
