A/C FAN?
It'll come on to cool the radiator at idle since there isn't airflow going through the radiator, to cool it. If the a/c compressor is on it'll either have it's own fan to help draw out heat or use the radiator fan if you only have one.
i am putting a small t25 turbo on this spring on a sohc zc but i also want to keep ac and was wondering if i could get rid of the full rad and use a log mani i could most likely keep a/c
you can have a half radiator...that is not the issue. the 2nd fan is for the a/c condenser, to cool it off. as long as the condenser is installed with it's fan, you can do whatever you want with the radiator.
User 42624
Aug 4, 2006 05:17 PM
